1988 Slight backfire under acceleration
Results 1 to 11 of 11
Cadillac Allante Forum Discussion, 1988 Slight backfire under acceleration in Past Cadillac Vehicle Discussion; As I mentioned in a previous post, just purchased a 1988 Allante. Car is in great shape, starts easy, runs ...
    ncpi is offline Cadillac Owners Member
    Automobile(s): Allante
    Jun 2013
    11
    As I mentioned in a previous post, just purchased a 1988 Allante. Car is in great shape, starts easy, runs great...with one exception...there is a slight backfire (pop) under acceleration. Sounds like just one cylinder missing sometimes. I do not know the history on this car. Is this a common problem and is there something I should look at first?
    Thanks for your help!
    Bill
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: 1988 Slight backfire under acceleration
    Pop from under hood or from the tail pipe? From the tail pipe I would suspect plug wires. Are we talking about quick acceleration? A series of pops?
    Jun 2013
    11
    Quote Originally Posted by carnut View Post
    Its from the tail pipe. It does it even under "moderate" acceleration, you have to be very gentle to not have it pop. It is a series of pops but separated by time such that I think its only one cylinder. You think its the plug wires? I was kind of thinking maybe a fuel injector that wasn't closing all the way or maybe a sticking valve. Plug wires would be easy to start with.
    Thanks, Bill
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Yeah, a "backfire" from the tailpipe is called a "muffler report". It's caused by fuel vapor in the exhaust. Either too much fuel is being injected (faulty FPR, stuck injector...), or there's a misfire.
    Jun 2013
    11
    Thanks guys. Is there a preferred Spark Plug brand/type that works the best with these engines?
    Jun 2013
    11
    Along with Spark Plug brand/type... Is there a procedure somewhere on how to best get to the rear spark plugs to change them?
    Feb 2003
    california
    69
    6,689
    I used the Delco plugs designed for a 91 4.5 Eldo. platinum so they go 90,000 miles. When I did mine, I removed the 2 front sub frame bolts and lowered the engine slightly with a floor jack to gain more rear access. Plan on wires, They will be stuck on the plugs!
    Fuel pressure regulator is rather uncommon to fail on this engine. With the service manual instructions, you can short out each cylinder thru on board diagnostics to isolate which cyl is acting up.
    Jun 2013
    11
    Thanks Carnut. I hope I can figure out which 2 bolts to remove. Is it obvious?
    I ordered AC Delco platinum plugs, wires and cap/rotor from Rockauto...just waiting for delivery and time to work on it. Also just ""won" an eBay bid for a factory 1988 service manual. yea!
    Feb 2003
    california
    69
    6,689
    2 large bolts holding the front of the sub frame holding the engine! Be careful. Dont hit the fan with the engine.
    Jun 2013
    11
    BTW. New platinum plugs, wires, distributor cap and rotor did the trick! I guess after 25 years, they needed replacing
    Feb 2003
    california
    69
    6,689
    Thanks for the update. This will help someone else.
  14. Remove Advertisements
