1987 won't shift into 2nd until it warms up!
Results 1 to 8 of 8
Cadillac Allante Forum Discussion, 1987 won't shift into 2nd until it warms up! in Past Cadillac Vehicle Discussion; The Car is a 1987 Allante with 137,000 miles, 4.1 L engine . It will not shift from 1st to ...
    fjl248 is offline Cadillac Owners Member
    Automobile(s): Cadillac Allantes 1987 & 1992
    Jan 2008
    Georgia
    14
    The Car is a 1987 Allante with 137,000 miles, 4.1 L engine . It will not shift from 1st to 2nd until I drive itslowly
    for about a half of a mile (longer in cold weather). Then it shifts perfectly. I have had transmission fluid changed.
    This is an ongoing problem. Any advice will be appreciated
    Feb 2003
    california
    69
    6,680
    Re: 1987 won't shift into 2nd until it warms up!
    I would make sure the TV cable from the transmission to the throttle pivot is adjusted correctly 1st. A cable adjusted too short will delay the shifts especially when the fluid is cold. Any trans shop can do it in about 10 min. You release a collar lock on the cable at the bracket it attaches to, then rotate the throttle to wide open. The TV cable should extend to seek its proper length and you re lock the collar.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by carnut View Post
    It's been a while since I opened one of these, but I seem to remember it having shift solenoids unlike the regular 440's. Correct?
    Feb 2003
    california
    69
    6,680
    My point was to verify the external adjustment is correct as an aid in diagnosis.
    Feb 2012
    NYC
    50
    1,948
    I was asking. Are they solenoid controlled? I think they are.
    Feb 2003
    california
    69
    6,680
    Yes they are. And are specific to an 87 Allante.
    Jan 2008
    Georgia
    14
    I had the mechanic make this adjustment. It seemed to make a very slight improvement in the time it took to shift into 2nd. What is this about a solenoid. Do yyou have to take the trnsmission out to fix it? I have antifreeze leaking from back lower side of engine. Was told it might be a faulty xpansion freeze plug and that to fix it would require dropping the transmission
    smumfor's Avatar
    smumfor is offline Cadillac Owners Member
    Automobile(s): 89 Allante / 90 Allante
    Jun 2003
    Jacksonville, FL
    21
    My 89 did this 2 years after being rebuilt.. I would not shift until I got to the end of the street.
    What happens if you just let the car sit for 10 min in the morning warming up?
    I had a fluid and filter change and it's fine now..
    Scott
  11. Remove Advertisements
