93 Allante Cruise Control Repairs
Results 1 to 5 of 5
Cadillac Allante Forum Discussion, 93 Allante Cruise Control Repairs in Past Cadillac Vehicle Discussion; The light on the dash works at engine start up. The fuse in the center console is good. Any suggestions ...
    PEARLCONV is offline Cadillac Owners Member
    Dec 2004
    4
    Smile93 Allante Cruise Control Repairs
    The light on the dash works at engine start up. The fuse in the center console is good. Any suggestions what to try next ? Thank You!
    Feb 2003
    california
    69
    6,666
    Re: 93 Allante Cruise Control Repairs
    Try putting your foot under the brake pedal and lifting up then engage the cruise. Sometimes the switch on the brake pedal is misadjusted. Lifting up on the pedal sometimes will readjust the switch.
    Dec 2004
    4
    Thank You. I will try it.
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    If you have a factory service manual, there is a procedure for testing all the switches in the PCM Input parameters section, specifically PI70, PI71, PI82, PI83, and PI84. There is also an override procedure at PS07 to try to pull in the servo. Running all these tests should help you pinpoint the problem. If you don't have a shop manual, I think we have an extra one.
    Dec 2004
    4
    I did buy a manual. I will try the easy fix first. Thanks.
  8. Remove Advertisements
