93 with electrical and/or battery problems
Results 1 to 2 of 2
Cadillac Allante Forum Discussion, 93 with electrical and/or battery problems in Past Cadillac Vehicle Discussion; 93 giving battery not charging message. I can charge existing Bosch battery on low charge and it will start but ...
    DelaineJohnson is offline Cadillac Owners Member
    Automobile(s): 93 Allante
    Apr 2012
    Austin, Tx
    1
    93 giving battery not charging message. I can charge existing Bosch battery on low charge and it will start but still runs battery down quickly. Battery is 6 years old. Delco apparently does not make the exact replacement. The battery could certainly need replacing but there is something wrong downstream too. What is most common cause of problems you see with this. Looking for suggestions and battery source.
    KrisK is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood Brougham; 1993 Pinninfarina Allante
    Dec 2010
    Arlington, TX
    65
    Re: 93 with electrical and/or battery problems
    Sounds like your alternator is bad.
