1987 Alante running problems
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, 1987 Alante running problems in Past Cadillac Vehicle Discussion; I've got a 1987 Alante with 40k that all of a sudden sounds like its running on 5 or 6 ...
    bj58348 is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville STS
    Aug 2010
    7
    I've got a 1987 Alante with 40k that all of a sudden sounds like its running on 5 or 6 cylinders. Starts up reasonably easy under the circumstances. The exhaust sounds loud as well. Any ideas? Also, how do you pull the codes?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Have the plugs and wires ever been changed? 40K is great and all, but after 25 years, original plugs and wires should be considered ancient, and are highly suspect.
    I'm not sure if the Allante has the ability to display codes on the DIC, I assume it does though. Try the steps in this sticky:
    http://www.cadillacforums.com/forums...-pre-98-a.html
    carnut is online now Cadillac Owners Master
    Feb 2003
    california
    69
    6,680
    Re: 1987 Alante running problems
    Having the ability to pull codes and no service manual is like having the bullets and no gun! If its not plugs and wires then you have either a wiring connector at an injector thats loose or an injector thats failed. With a service manual, you can short out each injector to locate the faulty cylinder. Once located, then you can determine if its a spark plug, wire or injector.
    Sep 2010
    East Boston MA.
    29
    26,325
    Ah, I'd forgotten that the Allantes version of the 4.1 had multi-point injection. Should be easy enough to just unplug each injector, no?
  7. Remove Advertisements
