brake pump pressure hose
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, brake pump pressure hose in Past Cadillac Vehicle Discussion; My newly acquired '91. Brakes are hard as rocks (no boost), so I applied 12 to the pump and within ...
    Harry Yarnell is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    73
    903
    Brakes are hard as rocks (no boost), so I applied 12 to the pump and within 1-2 seconds, the hose going from the pump to the MC, blew.
    Now, how do you remove this hose? Looking at it quickly, it looked like a brake fitting type of connection just an 1" within joining the pump and MC, but brushing the diry away, I see no hex ferrel, it's just round. How do you get this hose apart?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: brake pump pressure hose
    If I remember, a hollow bolt passes thru the center of the connection with copper crush washers on either side like most european fuel line connections.
    Dec 2004
    perryman, MD
    73
    903
    Well I got a new hose assy made up by a hose builder in Baltimore, but the brakes are still rock hard (no boost). The pump runs for about a minute from overnight sitting, and comes on for 5-10 seconds when the brake is applied. There is no ongoing BRAKE dash lamp.
    Any ideas?
    Feb 2003
    california
    69
    6,689
    The electric pressure pump is weak. The ideal run time is approx 30 seconds. Did you review the DIY on allantesource.com regarding ABS diagnosis? I went thru 2 rebuilt?? pumps before a low mileage original fixed my hard pedal.
    Dec 2004
    perryman, MD
    73
    903
    ...but wouldn't the BRAKE lamp illuminate if the pressure is low? I'll try to cobble a fitting and pressure gauge to the bleed port and see what it is. Hope I have a gauge that goes high enough. Book says something like 1500#.
    Dec 2004
    perryman, MD
    73
    903
    Hooked up a pressure gauge to the bleed port, and it pegged (500#) after 5 seconds of running the pump. It was the highest pressure gauge I had. More testing is required; I'll try to find a higher pressure gauge.
    Feb 2003
    california
    69
    6,689
    Did you do the diagnosis on wwwallantesource.com?
  10. Remove Advertisements
