Results 1 to 4 of 4
Thread: 93 Allante wheel swap
    shotout1234 is offline Cadillac Owners Member
    Automobile(s): 93 Allante
    Oct 2011
    1
    Question 93 Allante wheel swap
    Will a set of 4 04 CTS 17" oem wheels be a direct bolt on swap? They have the same bolt pattern 5x115 and same hub bore. My issue is the offset and my concern is one is rwd and the other fwd. Are all 4 wheels the same on each? Thank you for any info that you might have. Todd
    KrisK is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood Brougham; 1993 Pinninfarina Allante
    Dec 2010
    Arlington, TX
    65
    Re: 93 Allante wheel swap
    direct swap with no issues
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    this is one of the most common wheel swaps on an allante from what ive seen
    edit: that comment wasnt meant to take away from the swap itself. its obviously a good idea if its so popular. it was meant to say its common therefore its easy and no work or mods required and also no problems have arisen from it
  5. #4
    bruce's Avatar
    bruce is offline Cadillac Owners Member
    Automobile(s): 92 Allante (205K), 91 Allante (135K)
    Jun 2003
    Concord, CA
    10
    This photo reflects the 17" CTS wheels I put on my '92. I love the new look and receive many compliments on the car. The only adjustment issue I had was the front wheel caps would not fit over the axel ends. I took the silver cover off the plastic cap and cut the center out, then placed the shiny cover back on. Snapped on the wheel as if it were stock and has gone over 9,000 miles without issue! Go for it!
  • You may not post replies
