Flickering lights?
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, Flickering lights? in Past Cadillac Vehicle Discussion; Dash lights, headlights, fog lights, brake lights, information center lights, dome lights, radio lights......they ALL flicker any ideas on this ...
    m0ng0 is offline Cadillac Owners Member
    Automobile(s): 1993 Allante, 1973 Eldorado Convertible
    Apr 2007
    Battle Ground, Wa
    46
    42
    Flickering lights?
    Dash lights, headlights, fog lights, brake lights, information center lights, dome lights, radio lights......they ALL flicker any ideas on this ?
    Also I got a clunking under my feet as in drivers side near the pedals that comes and goes, usually it appears when the road gets unsettled.
    Also is there a way to pull the codes without using the info center? Mine is not functioning properly so I cannot pull the codes, is there another way ?
    Cheers all and I gotta say I just love this damn car !
    KrisK is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood Brougham; 1993 Pinninfarina Allante
    Dec 2010
    Arlington, TX
    65
    Re: Flickering lights?
    not sure but the flickering lights sound like bad grounds.
    Apr 2007
    Battle Ground, Wa
    46
    42
    behind/under the dash kind of bad grounds? i am going to do the front brakes this weekend so maybe I find something broken or loose to make that clunking sound ....fingers crossed
    Dec 2010
    Arlington, TX
    65
    Put the front end on stands and get under there and give it a good look see. Grab each wheel and shake hard. As for the grounds, check your FSM, start with common grounds to the lights and go from there.
    Apr 2007
    Battle Ground, Wa
    46
    42
    well solved the chuggle with 2 new coil packs, runs like a bat out of hell now ! Any ideas on how to run onboard diagnostics when the normal way wont work? it works once in a blue moon but 9 times out of 10 it wont (((((
    Johnny_Buchanan's Avatar
    Johnny_Buchanan is offline Cadillac Owners Fanatic
    Automobile(s): Allante '88
    Jun 2009
    Finland
    51
    143
    If DIC is not working you can try to pull codes with scanner. Pop in to a shop near you if you don't have one.
    -J
    Apr 2007
    Battle Ground, Wa
    46
    42
    Flickering lights (thruout the entire car) solved with a new alternator, front end issues were related to a bad wheel bearing!
  10. Remove Advertisements
