Fuse locations and ratings for 1989 Cadillac Allanté
Results 1 to 2 of 2
Cadillac Allante Forum Discussion, Fuse locations and ratings for 1989 Cadillac Allanté in Past Cadillac Vehicle Discussion; ...
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    The 1989 Allanté has 3 fuse panels
    The main one is located under the ash tray and uses "regular" sized fuses
    One is located in the battery compartment right behind the battery.
    Lastly, one is located in the trunk, on the passenger side, in the same compartment the power antenna retracts into
    The ratings and functions of the fuses in the "main" block are as follows:
    COLUMN ONE
    1 - (3 AMP) INSTRUMENT PANEL
    2 - (5 AMP) CLIMATE CONTROL/DIC PANEL
    HEATER AND A/C PROGRAMMER
    LOW COOLANT LEVEL
    AIR UP-DOWN ACTUATOR
    3 - (3 AMP) COOLANT FAN
    OUTSIDE MIRROR DEFOGGER
    BODY COMPUTER MODULE
    4 - (7.5 AMP) INJECTORS 1 4 6 7
    5 - (7.5 AMP) INJECTORS 2 3 5 8
    COLUMN TWO
    6 - (25 AMP) WINSHIELD WIPERS/WASHERS
    HEADLAMP WASHERS
    CRUISE CONTROL
    POWER MIRRORS
    7 - (10 AMP) RADIO
    8 - (15 AMP) BRAKE SWITCH
    CENTRAL POWER SUPPLY
    9 - (10 AMP) HEADLAMPS
    PARK LAMPS
    FOG LAMPS
    TWILIGHT SENTINEL
    INTERIOR LIGHTS
    HAZARD WARNING FLASHER
    RETAINED ACCESSORY POWER
    RADIO
    CHIME MODULE
    10 - (30 AMP) SPEED DEPENDENT DAMPING
    A/C LOW PRESSURE SWITCH
    HEADLAMP WASHERS
    COLUMN THREE
    11 - (3 AMP) BODY COMPUTER MODULE
    12 - (15 AMP) FUEL PUMP
    13 - (15 AMP) VISCOUS CONVERTER CLUTCH
    AUTOMATIC TRANSAXLE
    CANISTER PURGE SOLENOID
    14 - (10 AMP) ENGINE CONTROL MODULE
    PASS KEY DECODER MODULE
    15 - (10 AMP) BODY COMPUTER MODULE
    CHIME MODULE
    INSTRUMENT PANEL CLUSTER
    HEADLIGHT REDUNDANT RELAY
    THEFT DETERRENT
    FUEL TANK UNIT
    TAIL LIGHT REDUNDANT RELAY
    COLUMN FOUR
    16 - (15 AMP) TRUNK RELEASE
    CONSOLE LIGHT
    17 - (10 AMP) RADIO
    CLIMATE CONTROL/DIC
    18 - (20 AMP) CIGAR LIGHTER
    FUEL DOOR RELEASE
    19 - (7.5 AMP) CRUISE CONTROL
    OUTSIDE MIRROR
    WINDSHIELD WIPERS/WASHER
    HEADLAMP WASHER
    20 - (20 AMP) OUTSIDE REAR VIEW MIRROR DEFOGGER
    COLUMN FIVE 21-24 ARE BREAKERS NOT FUSES
    21 - (30 AMP) RETAINED ACCESSORY POWER
    22 - (30 AMP) POWER DOOR LOCKS
    POWER SEATS
    MEMORY SEAT
    23 - (30 AMP) RETAINED ACCESSORY POWER
    24 - (30 AMP) REAR DEFOGGER
    HARD/SOFT TOP PULL DOWN UNIT
    25 - (20 AMP) UNDER HOOD LIGHT
    TRUNK LIGHT
    LUGGAGE COMPARTMENT LIGHT
    VANITY MIRRORS
    OVERHEAD READING/COURTESY LIGHTS
    GLOVE BOX LIGHT
    POWER DOOR LOCKS
    The ratings and functions of the fuses in the block behind the battery are as follows:
    MAXI FUSES - FROM BOTTOM TO TOP
    1 - (20 AMP) OVER VOLTAGE PROTECTION RELAY
    2 - (20 AMP) IGNITION
    3 - (20 AMP) BRAKE SWITCH
    LEFT SWITCH POD
    RADIO
    CHIME MODULE
    BODY COMPUTER
    4 - (20 AMP) ENGINE CONTROL MODULE
    PASSKEY DECODER MODULE
    5 - (40 AMP) POWER MODULE
    TRUNK LID PULL DOWN UNIT
    6 - (30 AMP) OUTPUT SWITCH MODULE 13
    OUTPUT SWITCH MODULE 7
    OUTPUT SWITCH MODULE 6
    7 - (60 AMP) INTERIOR LIGHTING
    EXTERIOR LIGHTS
    8 - (20 AMP) DELCO-BOSE MUSIC SYSTEM
    SPEAKER RELAY
    POWER ANTENNA
    TRANSCEIVER
    The ratings and functions of the fuses in the block IN THE TRUNK are as follows:
    MAXI FUSES - FROM TOP TO BOTTOM
    1 - (20 AMP) BACK UP LIGHTS
    HIGH MOUNTED STOP LIGHT
    REAR SIDE MARKER LIGHTS
    LICENSE PLATE LIGHT
    INTERIOR COURTESY LIGHTS
    2 - (20 AMP) LEFT STOP/TURN SIGNAL
    3 - (20 AMP) RIGHT HEADLIGHT
    FRONT SIDE MARKER LIGHTS
    LEFT FRONT PARK/TURN SIGNAL
    LEFT HEADLIGHT
    LEFT FOG LAMP
    Dajudge55 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS, 2011 SRX, 1989 Allante
    Sep 2009
    Tennessee & Florida
    79
    50
    Re: Fuse locations and ratings for 1989 Cadillac Allanté
    Thanks so much for the fuse locations and ratings. This is gonna help a lot !!!
    Larry
