cooling fans 89 Allante
Results 1 to 5 of 5
Cadillac Allante Forum Discussion, cooling fans 89 Allante in Past Cadillac Vehicle Discussion; Hello fellow Allante owners, I am new to this site, as a owner of an 89 I have a problem. ...
    dustypatch101 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2008
    11
    Hello fellow Allante owners, I am new to this site, as a owner of an 89 I have a problem. the coolng fans are on hi as soon as the Allante is started they do not sut off until the ign. is turned off. it appears that someone has wired the fans directly you the run mode any help would be greatly apprecated
    Stu ( in B.C. Canada
    abweiss is offline Cadillac Owners Member
    Apr 2006
    South Jersey
    11
    Re: cooling fans 89 Allante
    Our fan control module fails and allot of people bypass it, the modle is located behind the bumper and Johnny Monzo from CadillacAllanteClub.com sells it he can be reached at 609-634-6518
    Jul 2008
    11
    Thanks abweiss, I did have a feeling it has been bypassed, I know Eldo has the same module, nothing in NOS is avaible through GM. I will be in contact with the Cadillac Allante club. once again thanks Stu
    wcoates is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Red Allante,
    Nov 2005
    Canfield Ohio
    313
    I received mine from Dick Hussey at Allantesource.
    561-844-3938
    Feb 2003
    california
    69
    6,663
    The Eldo and Seville modules are located on the radiator support and seem to last longer in the air stream. On my 88 it failed to go to max fan speed and I replaced it with a Seville PICK N PULL one.
  8. Remove Advertisements
