Results 1 to 4 of 4
Thread: 1993 Allante speedometer problem
    giants1954 is offline Cadillac Owners Member
    Automobile(s): allante
    May 2011
    Hello Guys---
    Have a 93 Allante with analog instruments. Battery went bad during the winter-60 months exact--tried to start---I think low voltage caused a problem with the speedometer--it went from 0-140 MPH and pegged itself and has stayed there.
    Replaced the battery--everything seems to work perfect--but the speedo is pegged and does not move--ignition on or off.
    Hopeing the wisdom of the group can help.---Ray
    D Yaros's Avatar
    D Yaros is offline Cadillac Owners Fanatic
    Automobile(s): 1955 CDV, 1992 Allante, 1962 Olds 88 Conv
    Nov 2009
    Milwaukee
    182
    Re: 1993 Allante speedometer problem
    I am having a little trouble wrapping my head around this one. If it is an analog dash, the speedo should be mechanical, not electrical. I cannot comprehend how changing the battery here would case the needle to peg out at 140 MPH? May sound dumb, but have you tried tapping on the speedometer cluster?
    May 2011
    An electrical pulse sending unit at the tranny sens pulses to the speedo. Yes--I tried tapping on the cluster to no avail. But--we all get lucky once in a while. I decided to do another road test and try the cruise control for confirmation of failure. I didn't expect it to work but nothing ventured? Set up at aprox 40 MPH and voilla--the cruise engaged-but still 155 MPH on the speedo. Decided to accelerate the cruise to see what happens? At about 55 MPH--the speedo suddenly dropped to 55 MPH and has acted normally the rest of the test drive. Did a shut down -and started up-all good! Thanks so much for just offering an idea----Ray
  5. #4
    D Yaros's Avatar
    Nov 2009
    Milwaukee
    182
    Glad you found a solution. Great improvisation/thinking on your part!
  • You may not post replies
