Replacement bulb for center stop lite
Results 1 to 6 of 6
Cadillac Allante Forum Discussion, Replacement bulb for center stop lite in Past Cadillac Vehicle Discussion; I needed a replacement, it's a 894 bulb (1 piece with socket), of course, no one has it. However, there's ...
    electricman is offline Cadillac Owners Member
    Automobile(s): 93, 98 eldo, 91 allante, '67 GTO
    Sep 2009
    palatine, il.
    45
    However, there's a Sylvania 880 which is the same, 27W, drops right in. Got mine at Oreilly's.
    George
    FLBill is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac
    Oct 2010
    54
    57
    Re: Replacement bulb for center stop lite
    Hey- -
    Doesn't GM carry this bulb?
    Bill
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    i read on another forum that tractor supply stores carry the 894 bulb. apparently it was used in a snowblower?
    wcoates is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Red Allante,
    Nov 2005
    Canfield Ohio
    313
    Be careful an 892 is the bulb you want. others are a guarantee to melt (warp) the lense.
    Sep 2009
    palatine, il.
    45
    That's what I was afraid of; the bulb I removed matched the spec in the owner's manual (so it was original) and it clearly stated on the base 27W.
    The Sylvania 880 exactly matched the physical base and wattage so I ASSUME that it should work the same; i.e. shouldn't damage the lens. I thought that 27W is a bit much for the confined space of the center stop lite, but it is original.....
    Just took a look at a 892 bulb, Ge #16481, its a 16.8W that looks like it'll fit. I'll look around for it; may be the safer choice.
    George
    Sep 2009
    palatine, il.
    45
    Wcoates is right...I checked my owner's manual and it states the bulb should be a 892 (16W).
    Interesting; I removed my "original" bulb and it is a 894 (27W). The previous owner must have replaced the original bulb with a 894.
    I don't see any lens problems (yet), but I'll replace it with the proper one.
    Moral is always check the manual first!
    George
  9. Remove Advertisements
