The headlights just keep flashing?? AArggg!!!
Results 1 to 8 of 8
Cadillac Allante Forum Discussion, The headlights just keep flashing?? AArggg!!! in Past Cadillac Vehicle Discussion; I don't know what to do anymore!!...
    mark antony is offline Cadillac Owners Member
    Automobile(s): allante
    Sep 2010
    8
    Feb 2003
    california
    69
    6,663
    Re: The headlights just keep flashing?? AArggg!!!
    If its the alarm, put the key in the driver door lock and lock, unlock the car. The alarm should also activate the horn, but my 88 sometimes would not.
    94ZR1 is offline Cadillac Owners Member
    Automobile(s): 93 Allante
    Aug 2010
    54
    15
    Also there is a circuit breaker in the headlight switch that could cause this
    Try the alarm first though
    Sep 2010
    8
    I went out this morning and locked and unlocked the driver door and shazam the lights worked. Thankyou carnut, I was at my wits end. I've got every panel off this car tracking wiring and all, replaced relays, assuming OSM's were bad, thought the BCM would need replacing, but all I had to do was stick the key in the door. Thankyou, and thankyou again.
    Feb 2003
    california
    69
    6,663
    You are welcome. The alarm is set each time you exit the car and you touch the power door lock button when shutting the door. If the right door lock is not fully locking or if the drivers door lock is not fully locking that would cause this flashing light problem upon opening either door. The rods that move the lock paddle in each door are adjustable thru a threaded rod and I've also seen the window wire bundle not nylon wire tied to the door inner panel which can cause binding of the rods movement against this bundle.
    Sep 2010
    8
    The headlights only work during the daytime, at night they start flashing again. the tailights are working until the headlights are turned on, then they start flashing also. the parking and fog light buttons don't seem to work and the twilight sentinel button won't shut off. I will open my extra headlight switch and locate the circuit breaker and also check into the door locks. The flashing must be an alarm problem, I am guessing
    Aug 2010
    54
    15
    If the twilight sentinel will not turn off then something is wrong there
    My car already had a service manual with it
    It has saved me many times
    I will check it out when I get home and bring it with me to work tom
    I dont have internet at home
    Sep 2010
    8
    Now I have noticed that the lights work with the engine off. They start flashing when the motor is started.
  11. Remove Advertisements
