Source for replacement '91 muffler or fabricate?
Results 1 to 6 of 6
Cadillac Allante Forum Discussion, Source for replacement '91 muffler or fabricate? in Past Cadillac Vehicle Discussion; IS there a reasonable source for the muffler or should I fab up a replacement with some nice exhaust tips, ...
    electricman is offline Cadillac Owners Member
    Automobile(s): 93, 98 eldo, 91 allante, '67 GTO
    Sep 2009
    palatine, il.
    45
    IS there a reasonable source for the muffler or should I fab up a replacement with some nice exhaust tips, etc?
    george
    Feb 2003
    california
    69
    6,663
    Re: Source for replacement '91 muffler or fabricate?
    On my 88, I used a mid 90's Z28 muffler and added another cut out under the right rear of the bumper. Used aftermarket stainless rectangular tips that mimicked the Z28 tips but were better quality. It sounded great at idle and under power but was quiet otherwise.
    Moose123 is offline Cadillac Owners Member
    Mar 2009
    88
    I suggest you check with Dick Hussey at www.allantesource.com
    Sep 2009
    palatine, il.
    45
    First, my cat converter is rattling so I'm going to replace it with a pipe, (pre-96 is exempt from emissions test in Illinois), then I'm going to use a Magnaflow stainless muffler and a dual stainless, round, rolled exhaust tip existing in the standard location.
    I'll need to fab some pipe since the '91 uses a 3" flange on the cat, a 2-3/4" pipe to the back into the muffler, and then a 2-1/2" pipe out of the muffler to the rear exhaust.
    The 2-3/4" adapters from 3' and then down to 2-1/2" into the Magnaflow muffler are more difficult to find.
    I may check with a exhaust shop about making up some of the necessary pipe chunks to eliminate joints.
    George
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur
    Automobile(s): 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,396
    Was the muffler Allante-only or did GM pull it out of the parts bin somewhere? Maybe the same as used on those years Eldo or Seville.
    FLBill is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac
    Oct 2010
    54
    57
    Hi
    Ebay?
    Bill
  9. Remove Advertisements
