fuel door
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, fuel door in Past Cadillac Vehicle Discussion; Fuerl door wnt open i have checked fuse is there and overide somewhere...
    kingnoble is offline Cadillac Owners Member
    Automobile(s): 1992 Allante
    Jul 2010
    73
    6
    fuel door
    Feb 2003
    california
    69
    6,680
    Re: fuel door
    Remove the inner carpeted panel behind the driver seat that surrounds the rear speaker. It slides forward in a track. Once removed look inside behind the gas filler recess for the manual release lever. Alot of people add an extention to it that reaches just beyond that carpet panel once its reinstalled. While the panel is out verify voltage at the release solenoid there. Most times its simply a matter of lube on the hinge or dielectric grease applied to the wire plug on the solenoid contacts to restore operation.
    Jul 2010
    73
    6
    Re: fuel door
    Thanks for the info, but I got lucky the connector at the switch was loose
