Transmission Drain Plug?
Results 1 to 5 of 5
Cadillac Allante Forum Discussion, Transmission Drain Plug? in Past Cadillac Vehicle Discussion; Can anyone provide a good reason why car manufacturers don't put a drain plug in the automatic transmission pan? What ...
    Moose123 is offline Cadillac Owners Member
    Automobile(s): 1988 Allante
    Mar 2009
    88
    Can anyone provide a good reason why car manufacturers don't put a drain plug in the automatic transmission pan? What a pain in the neck when you change the transmission fluid. I know one can be added, but what the heck...It would be so simple at the factory.
    Feb 2003
    california
    69
    6,680
    Re: Transmission Drain Plug?
    #1 reason. It adds 10 cents to the cost of building the car.
    Mar 2009
    88
    Carnut- Excellent point! of course...
    macsr is offline Cadillac Owners Member
    Automobile(s): 2010 RED CTS SEDAN
    Jan 2010
    Yukon Oklahoma
    69
    48
    I have always heard that because you are suppose to change the internal filters when changing fluid and the pan must come off anyway there was no need for drain plug. Other than the mess that you have to clean up when taking off the pan. I am sure that the 10 cent cost is also an issue.
    D Yaros's Avatar
    D Yaros is offline Cadillac Owners Fanatic
    Automobile(s): 1955 CDV, 1992 Allante, 1962 Olds 88 Conv
    Nov 2009
    Milwaukee
    180
    #2 Reason is, if there was a drain plug, more folks would be likely to drain/flush their trans, than go to the dealer for such service!
  8. Remove Advertisements
