Phase I top on phaseII car anyone?
Results 1 to 7 of 7
Cadillac Allante Forum Discussion, Phase I top on phaseII car anyone? in Past Cadillac Vehicle Discussion; Has anyone retrofitted a P1top on a P2 car with one of the kits available? I'm looking at buying a ...
    urljive is offline Cadillac Owners Member
    Automobile(s): 90 allante 66 deville
    Feb 2009
    62
    4
    Has anyone retrofitted a P1top on a P2 car with one of the kits available? I'm looking at buying a P1 top for my P2 car and need some feedback on the fit of the kit and if the latch kit works well as far as wind noise, leaks & squeaks.
    I cannot find a P2 top anywhere in Ontario and the P1's are definitely more plentiful and affordable.
    electricman is offline Cadillac Owners Member
    Automobile(s): 93, 98 eldo, 91 allante, '67 GTO
    Sep 2009
    palatine, il.
    45
    Re: Phase I top on phaseII car anyone?
    I bought the kit a few months ago but haven't done the conversion yet. It comes with a DVD with good instructions and I did watch it.
    The kit uses the side latches, mounts them on the front header plate of the top along with some machined parts that resemble the locking bearing used on the soft top header motors. The kit has instructions and dimensions for mounting.
    The header plate on the hard top and weather strip need to be trimmed somewhat since the receptacles on the later windshield frame protrude up. This area is where you get a bad seal if you don't trim the interfering areas.
    George
    wcoates is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Red Allante,
    Nov 2005
    Canfield Ohio
    313
    Just saw on another site that Scott Flack rsflack@yahoo.com has a conversion kit -never used at fire sale pricing of $75. or you could use the $.98 fix (suggest substituting an eye-bolt):
    Sep 2009
    palatine, il.
    45
    yeah, mine had that when i bought it...........it had an eyebolt, tho... same color headliner, actually.....
    I improved on that by making a small bracket from angle iron and using the same bolt hole. looks better than an eyebolt.
    Still, the mods for the front piece and weatherstripping are valid, because even with my latches tight, I still had a lot of windnoise/leakage thru the top of the windshield.
    George
    Nov 2005
    Canfield Ohio
    313
    Would be interested in seeing a pic of the bracket.
    Sep 2009
    palatine, il.
    45
    Here are some pix. I also made a "J" hook out of a hardware store "J" bolt, threaded it with the required metric thread, (8mm I believe), since the original hook was a bit too short in the "J" portion.
    George
    Feb 2009
    62
    4
    Thanks! I'm hoping to hear from a guy who has a P1 top for sale about 100 miles from me. I'm thinking of driving my car to him and putting the top on for the ride home. Maybe I'll use a strap or 2 to hold it on for the trip home
  10. Remove Advertisements
