New owner of 93 - high mileage car
Results 1 to 12 of 12
Cadillac Allante Forum Discussion, New owner of 93 - high mileage car in Past Cadillac Vehicle Discussion; Recently purchased a 93. It's showing 171K on the odometer and I have no history. Here's my question........ given the ...
    smith356's Avatar
    smith356 is offline Cadillac Owners Member
    Automobile(s): allante
    Apr 2010
    68
    5
    Recently purchased a 93. It's showing 171K on the odometer and I have no history. Here's my question........ given the mileage, do I assume it's gone this far and must have had needed fixes ? Read an old post saying these are interactive engines ( if timing chain breaks, kiss it goodbye ). Set me to thinking - water pump, starter, etc. Are these all serious/ expensive repairs ? I would love some input from those of you who have dealt with the Northstar in the Allante. My oil pressure is good.. coolant temp is good... power is awesome. I have seen a lot of comments about reaching a point where they become more valuable as parts than they are as a car... interesting. Anyhow, would love some input on how you have fared with this motor over the years........... Jim
    macsr is offline Cadillac Owners Member
    Automobile(s): 2010 RED CTS SEDAN
    Jan 2010
    Yukon Oklahoma
    69
    48
    Re: New owner of 93 - high mileage car
    Greetings Jim, I also am a new owner of a 93, mine last january. With only 94000 on mine I have not experienced any problems. The only major problem that I have heard about on the Northstar was with the cooling system and the need to change the antifreeze regularly. I have repaired my top pull down motor, changed coil pac's and plugs and wires. Other than that no problems. The later made 93's are better as all the early production problems were implemented later in the production. I have been told that the models with the serial numbers 127XXX and up are really the later ones. Also there is another Allante site that i have listed below where there is a wealth of information on these cars. You can have no question that 4 to 10 guys (and maybe a few girls) wont try to help you with. I would recommed that you go there and also ask that group the same question. I havent found a subject matter on my Allante that someone there has not experienced or found the fix for.
    Good luck with your car, I use mine for a daily driver and love the feel and the power. Its just incredible. Mike
    http://allante.us/cgi-bin/yabb/YaBB.pl
    babylac89's Avatar
    babylac89 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac Allante-Northstar
    Feb 2008
    "The OC"
    186
    Welcome Jim...as Mike said, the cooling systen is #1 on a 1993, so if you don't know the history, I would flush the system, just for insurance. And be sure to crush up and drop in three GM Cooling System Seal Tabs!
    Chief
    jminor is offline Cadillac Owners Member
    Automobile(s): none
    Aug 2009
    1
    great information. What is the best way to change the fluid, using the plastic adapters at home or having it serviced using the proper machine? Is there a best antifreeze to use?
    billc83's Avatar
    billc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 Allante, 1999 Deville Concours
    Nov 2008
    Seattle, WA
    34
    1,227
    The Northstar engine requires DEX-COOL coolant, not the normal green stuff.
    Keep an eye on your engine temperature. Head gaskets are the big issue with the Northstar - if they're blown you will lose coolant and start overheating. Do not let the engine overheat! It can't take it. If you catch the headgaskets early, one of the vendors on here sells studs which make it better than factory.
    Sounds like you have lucked out so far. Keep a watchful eye on the coolant temperature and enjoy the car.
    Jan 2010
    Yukon Oklahoma
    69
    48
    I would recommend that you do a little research on the type of coolant needed for your 93. My research led me to the green antifreeze for my 93. Cadillac may have changed later for the northstars but in 93 they came with green. I have read pros and cons on both colors, green and orange, so be diligent in your search and good luck. Mike
    Jan 2010
    Yukon Oklahoma
    69
    48
    Quote Originally Posted by jminor View Post
    The best information I have seen is to just open the drain plug on the lower right side of the radiator (bottom). The best way to get to is to pull the right fan motor. Let it all drain out and just replace. Dont really have to "flush" system. As Chief said be sure to use the GM pellets. Good Luck Mike
    babylac89's Avatar
    Feb 2008
    "The OC"
    186
    I've only used the DEX-COOL in mine.
    Chief
    smith356's Avatar
    Apr 2010
    68
    5
    Thanks, everyone. I'm a little more relaxed now about it. I will flush the system and get some pellets. Do I go to GM or are there other options to buying them ? Jim
    babylac89's Avatar
    Feb 2008
    "The OC"
    186
    Quite a few distributors sell them on line!
    Chief
    Hawker40 is offline Cadillac Owners Member
    Automobile(s): 1993 Allante
    May 2010
    1
    My 1993 has 42000 miles and is on sale on CL for 15750. No hardtop.
    Hawk
    babylac89's Avatar
    Feb 2008
    "The OC"
    186
    Please post pix, and CL in what city? Usually the pix in CL are a max of only four. The pix are what raises curiosity to want to see the car in person.
    Chief
  15. Remove Advertisements
