Won't Start and System Fault Message.
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, Won't Start and System Fault Message. in Past Cadillac Vehicle Discussion; (EDIT: I realize the thread title is misleading. The car did start afterwards but I have no idea why it ...
    billc83's Avatar
    billc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 Allante, 1999 Deville Concours
    Nov 2008
    Seattle, WA
    34
    1,227
    (EDIT: I realize the thread title is misleading. The car did start afterwards but I have no idea why it didn't start the first time around. Sorry for any confusion.)
    Anyway, the other day was nice so I figured I'd drive the Allante. After removing everything from in back (my garage is a mess right now), I went to fire it up but it won't start!
    - It had power, as the interior lights all worked fine, so that's not the issue.
    - It would not crank, and when attempting to, the DIC displayed "SYSTEM FAULT" message. Running codes afterward showed no current faults.
    - There was absolutely no noise showing any attempt to crank, just silence.
    Now, here's the kicker. After running inside to check online to what the problem may be, I figured I'd give it one more chance.
    It started up without a problem. Turned it off and it restarted fine, twice. Haven't had the issue since. What gives?
    Is this something I should be worried about, or is the Allante just jealous of the time I'm spending with my other car, so it's giving me a hard time?
    babylac89's Avatar
    babylac89 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac Allante-Northstar
    Feb 2008
    "The OC"
    186
    Re: Won't Start and System Fault Message.
    I'm going with the jealousy!!!
    Chief
    Ieradi's Avatar
    Ieradi is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Allante
    Oct 2007
    Media, PA outside of Philadelp
    53
    231
    Could be a loose ignition wire. If (or should I say when) this happens try and adjust the steering column a little (up or down) and give it a whirl.
