| Re: Anyone have a schematic for the digital instrument cluster ? The BCM must remain in the car. It stores the non eraseable mileage memory for your car. Yes you can get another cluster from that year of car. And by not working, what do you mean? ALL segments are inop? It would be unlikely that a totally blank cluster would be a faulty cluster. More likely the power feed to it. Has it been diagnosed? Verify with allantesource but I believe a 90 and 91 are the same regarding clusters. An analog display is a simple swap as well, if located, as long as the picture frame bezel around it is swapped as well. Used to swap my 88 from digital to analog on a whim. Took about 30 min. |
