I have a 87 alante and its running horrable. i though it was just plugs and wires. so i replaced the cap, rotor, wires and plugs. i don't have a owners manuel. i get a bunch of code history and only one current B447 not sure what that is.
the care runs really rough like its missing almost. i can have the petal to the floor and it takes about three blocks to get to 35 mph.
Hard to diagnose on line. You need to purchase a service manual, not an owners manual. The manual will walk you thru being able to short out each cylinder to locate the source of the miss. This car has very complete on board diagnostics for those that are mechanically competent. If you are not, the book will help your technician not guess at the problem. A good muffler shop can determine a plugged cat. converter. How old is the fuel filter. A plugged filter will restrict power but not cause a miss.
i took it into the shop. thier saying that the from the front mainifold to the muffler is pluged. the fuel filter is a couple of months old. could it just be the converter is pluged?
Yes, plugged cat. how many miles on this car? There's really nothing ahead of the cat that would plug. keep in mind that broken strata in the cat can enter and partially plug the muffler as well.
its has 108,000 miles on it. i'm hoping they tested the fuel injectors but, that was the first thing they asked about and did't get a check engine light. Is there an ECM code if an injector is bad?
I've had 2 different injectors fail on mine this year and no codes, no messages. It did affect the oxy sensor readings when monitored, but was not lean enough to pop a code. Keep in mind history codes can be an hour or a year old.
i got it back from dealership they said they went through the hole fuel injection and didn't find anything. Hoping for it to be just the cat. and muffler.
Your symptoms sound exactly like my son's S-10 that had a clogged cat due to a bad O2 sensor. Since the truck was still under the 80K emissions warranty, the independent mechanic loosened the exhaust system and my son drove the truck to the Chevy dealer with open headers.
Last night i was messing with mt car I haven't replaced the cat yet but, it did pop a code E030- ISC circuit problem. i ordered a owners and service manuel but they arn't here yet. and have no idea what that means.
