Starts, stalls, starts stalls, then runs like a champ
Results 1 to 8 of 8
Cadillac Allante Forum Discussion, Starts, stalls, starts stalls, then runs like a champ in Past Cadillac Vehicle Discussion; Title says it all! !Any words of wisdom on the new (to me) 90.5. leaving to change fuel filter and ...
    wcoates is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Red Allante,
    Nov 2005
    Canfield Ohio
    313
    leaving to change fuel filter and other fluids before church today! I be a prayin' for her health today!
    Allantesource is offline Cadillac Owners Fanatic
    West Palm Beach, FL.
    188
    Re: Starts, stalls, starts stalls, then runs like a champ
    Is this only when cold, or only when hot, or always, or ??? Possibly a fuel pressure regulator problem? Try this- turn the ignition on for a couple seconds, then off for a couple seconds three or four times before trying to start the car.
    Nov 2005
    Canfield Ohio
    313
    Dick
    when cold it didn't do the trick still stalled twice, gave it some gas and started and idled nicely. Warm and it started first try.
    Stealth's Avatar
    Stealth is offline Cadillac Owners Enthusiast
    Automobile(s): Is one enough ?
    Jun 2003
    So CA
    646
    Quote Originally Posted by wcoates View Post
    OK .. I'll bite .. what ?
    Feb 2003
    california
    69
    6,680
    The idle speed motor should be almost fully extended upon restart. Cold, it should idle in park at about 900 RPM, then slowly drop to approx 700 within 2 blocks. I think the ISC is either sticking, or not getting a signal to extend on start up. Moving the throttle moves the throttle plate instead of the ISC doing it I think. The manual spells out how to retract the ISC (engine running) to verify nose switch clearance and it also spells out how to command a full extension to verify TPS voltage reading. I would do both to confirm the ISC is working.
    Nov 2005
    Canfield Ohio
    313
    Thank Bill will try all suggestions!
    brock_landers is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    1
    Greetings,
    My mother is having the same problem with her 2001 DeVille and the dealer can't seem to find or want to find the problem. I was wondering it you have found the problem yet? Any imformation about this I would greatly appreciate.
    regards
    Feb 2003
    california
    69
    6,680
    A 2001 DeVille is completely different than a 90.5 Allante. 2001 DeVilles had issues with crank position sensors intermittantly failing, causing the engine to quit ramdomly. The dealer cannot verify because it usually never sets a code. The dealer can tho verify if the 2 crank sensors are the early or late design by color. If old design, replace them as insurance, they WILL fail.
  11. Remove Advertisements
