Turn Signals?
Results 1 to 12 of 12
Cadillac Allante Forum Discussion, Turn Signals? in Past Cadillac Vehicle Discussion; A question about the turn signal indicators. I do not have the owner's manual (yet) so I am asking here. ...
    Ieradi's Avatar
    Ieradi is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Allante
    Oct 2007
    Media, PA outside of Philadelp
    54
    231
    Turn Signals?
    I do not have the owner's manual (yet) so I am asking here. When I put on the turn signal, left or right, the indicator looks like <-> this. This is more like the symbol for 4 ways or flashers. I checked all the bulbs and they appear to be working. One side side light indicator is out though.
    Is this normal operation?
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur
    Automobile(s): 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,396
    Re: Turn Signals?
    I believe it is normal for some European vehicles. I had VWs in the 70s and 80s that did the same thing. When my son drove the car, he also questioned it.
    danstarley's Avatar
    danstarley is offline Cadillac Owners Member
    Automobile(s): 1990 Allante Phase I
    Apr 2007
    Guthrie, OK
    73
    26
    Re: Turn Signals?
    Yes, that is the normal indicator. The Allante only has one indicator, for both left and right turns. They cheaped out on that, but at least we got those classy chimes!
    wcoates is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Red Allante,
    Nov 2005
    Canfield Ohio
    313
    Re: Turn Signals?
    I have signal that goes each way as a normal car. I believe that has to do with the phase one car. My buddy Scott Flack who also had a '89 was made aware of the situation you described after be bought his '92. If I remember correctly Dick Hussey explained it as part of adding the airbag in 1990 and needing a connection. Doubled up on the turn signals and used the free spot for the needed airbag connection.
    See that you three gentlemen all have cars 1990 or newer.
    Ieradi's Avatar
    Oct 2007
    54
    231
    Re: Turn Signals?
    Quote Originally Posted by danstarley View Post
    Ahhh yes! Thanks for the answer. Can't wait for the owners manual to arrive so I can figure most of this stuff out!!!
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Turn Signals?
    WCOATS is correct. My 88 worked with 2 indicators, whereas my 91 does not. They used that space in the cluster to add the red "airbag" bulb.
    Stealth's Avatar
    Stealth is offline Cadillac Owners Enthusiast
    Automobile(s): Is one enough ?
    Jun 2003
    So CA
    646
    Re: Turn Signals?
    DITTO ...
    Phase I Allantes have left / right indicators
    Phase II & III do not and use the emergency indicator whether you are signaling left or right.
    That is the 2nd drawback over the Phase-I cars that I spot on the Phase II cars. This one is minor.
    Nothing to do with cheapening but a conflict of sorts with the design of the new circuits in the cluster involving the air bags.
    Nov 2005
    Canfield Ohio
    313
    Re: Turn Signals?
    Makes me wonder how many folks took their new $60,000 toy back to the service dept. for the "fix!". Can only imagine the responses !
    Onalaska's Avatar
    Onalaska is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SF, 1990 Allante, 2006 XLR-V
    Oct 2006
    Coldspring, Texas
    65
    270
    Re: Turn Signals?
    Kind of a surprise when I bought my 1990. With all the lighting technology in the design of the car that they couldn't have provided seperate turn signal indicators on the dash.
    c5 rv's Avatar
    Jun 2003
    Michigan
    4,396
    Re: Turn Signals?
    Quote Originally Posted by Stealth View Post
    Interesting point. As I mentioned earlier, I just figured it was an "European thing."
    People criticize the Allante dashboard. Maybe it's just my age, but I think it's cool, especially the center stack with a zillion black buttons canted toward the driver. I always have something to fiddle with. I'm not crazy about the yellow, electronic tach and speedometer, but I do appreciate the digital speed readout.
    Ieradi's Avatar
    Oct 2007
    54
    231
    Re: Turn Signals?
    DITTO ...
    So for my own clarification, is this a Phase difference or a year difference? Is it true that not all 1990'S are Phase I or Phase II? I thought from everything I read that the Phase II came with the 1990 1/2 vehicles?
    Stealth's Avatar
    Jun 2003
    So CA
    646
    Re: Turn Signals?
    Quote Originally Posted by Ieradi View Post
    Quote Originally Posted by carnut View Post
    That be correct, 1990 1/2 was the demarcation point. Easiest way to identify a Phase-II is by checking the latches for the tops.
    The problem is that ALL 1990's have airbags and I assume the turn signal thing is on all 1990 cars. So in effect, the turn signal thing is a Phase-II plus a few Phase-I cars in 1990.
    I got a thread called Allante XYZ Facts somewhere, do a google and take a look at it.
  15. Remove Advertisements
