Allante Rear Caliper Rattle
Results 1 to 3 of 3
Cadillac Allante Forum Discussion, Allante Rear Caliper Rattle in Past Cadillac Vehicle Discussion; We just bought a low miles '92. My mechanic has been pulling his hair out to figure out why we ...
    Maxwell is offline Cadillac Owners Member
    May 2004
    We just bought a low miles '92. My mechanic has been pulling his hair out to figure out why we still get the rattle. Sounds just like my Kawasaki when it needs front pads.
    Anyone now the fix? Thanks
    Max
    Roswell, GA
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Allante Rear Caliper Rattle
    I went through the rattle problem with a 91 Seville. It has the same basic set up as the Allante. After going through new bushings and pins, the rattle was still there. It wound up being excessive clearance between the new pads and the bracket they hang in. It was a combination of the new pads being shorter side to side and the bracket being worn where the pads would hang. Shims solved the problem and the rattle never came back.
    May 2004
    That makes perfect sense. We did change caliper bushings.
    Thanks for your help
    Max
