Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Allante Forum
Cadillac Allante Forum Forum for discussions regarding the exotic 2-seater Allante.
Cadillac Forums: 95 Allante engine upgrade question
Old 05-02-04, 12:32 PM
sorajt sorajt is offline
View sorajt's Photo Album
Casino Cash: $250
Would like to replace engine with a 2001 northstar. Anyone know if this is feasible ?
  #2 (permalink)
Old 05-02-04, 04:20 PM
Geno Castellano Geno Castellano is offline
View Geno Castellano's Photo Album
Casino Cash: $250
Re: 95 Allante engine upgrade question
I assume you mean a 93 Allante. No such thing as a 95 Allante.
Forget it. Anything later than a 1999 would be virtually impossible to get running in a 93 Allante. The Northstar engine changed significantly starting in 2000. In addition to the mechanical changes (roller cams, new cylinder heads, intake manfold, coil at plug ignition, etc...) the electronics of the engine and control system went to a completely different generation of controller and ignition. Impossible to adapt the old to the new...or vice versa. Even the crank sensors, crank sensor location and crank shaft reluctor wheel pattern changed....and are totally incompatible. The 2000 and later control system will not even run as a standalong system outside the cars it was developed for and if the car WAS rewired for the 2000 and later system the dash and such could not talk to the PCM. Forget it.
The only practical engine for a 93 Allante is a 93/94 vintage engine. Even a 95 or later requires significant rewiring, replumbing and cobbling of the engine support hardware. I would recommend sticking with the original engine.
What is the goal of the "upgrade" you envision? A 93 engine can be easily "refreshed" to like-new condition. There is no more power or driveability in a later engine so there is very little to gain by substituting a later model engine in the car.
  #3 (permalink)
Old 05-04-04, 03:13 PM
GERMEEZY1 GERMEEZY1 is offline
View GERMEEZY1's Photo Album
Casino Cash: $250
If anything the 93-94 Northstars are a little bit stronger on the Dyno than the later model engines. The only difference is a little more refinement but I liked the Muscle car feel of my 94 STS.
  #4 (permalink)
Old 05-05-04, 08:37 AM
Casino Cash: $250
Thanx for the replies. Yes - '93 - fumblefingers in original message. Looking to replace engine because one in the car locked up. 100k mi engine religiously maintained but .......... 9500 mi 2001 engine readily available from wreck. Guess I'll forget that idea. Thanx again.
  #5 (permalink)
Old 05-07-04, 09:47 PM
GSXNR's Avatar
GSXNR GSXNR is offline
View GSXNR's Photo Album
Casino Cash: $250
Couldn't you use the block and heads (or at least the block) from the 2001 and use everything else from the 93??
  #6 (permalink)
Old 05-08-04, 08:20 AM
El Dobro's Avatar
El Dobro El Dobro is offline
View El Dobro's Photo Album
Casino Cash: $325
The intakes are different to begin with. Keep an eye out on eBay, the 93-94 engines do pop up there for decent prices or you can do a Google for junkyards that deal in Caddy parts.
  #7 (permalink)
Old 05-14-04, 02:42 PM
Casino Cash: $250
No, not at all. The heads are completely different on the 2000 and later engines. The block itself might work but for a few details: The crank in the 2000 and later engines is completely incompatible with the 93 electronics because the reluctor wheel pattern is different. So the crank from the 93 would have to be used. The block won't work because the crank sensor locations are slightly different so the 93 crank sensors wouldn't work in a 2000 and later block even if the 93 crank were installed.
Tags: , , ,
allante, engine, question, upgrade
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
