| Cadillac Allante Forum Forum for discussions regarding the exotic 2-seater Allante. | Cadillac Forums: top pull down problem
09-22-07, 11:53 PM
| | Cadillac Owners Member Cadillac(s): Cadillac Allante 1988 | | Join Date: Dec 2006 Location: Towson MD Age: 63 | | | top pull down problem I have been having problems with battery drain. I have put in a switch to shut off fuse #8 at night. I have been doing this for a few week and everything works well. Today I opened the cover for the top pulldown motor and found some sparks at the emergence release cable, I tried to attach the top but the motor kept recycling up and down. After a few min it stopped and I can not get it to work any more. I have not disconnected the battery yet ( so I am not certain if the breaker kicked or not) At this point I have unplugged the motor and left the top down( this is the first time in a year I tried to put the top up) The cable to the normal release is frayed and it looks loose but I should be able to adjust, Is their any way to check the motor ? If I remove can I bench test? What is the price of a new motor? the price of a complete assy? is it easy to replace just the motor? Anything else we should try?
09-23-07, 02:00 PM
| | Cadillac Owners Member Cadillac(s): Cadillac Allante 1988 | | Join Date: Dec 2006 Location: Towson MD Age: 63 | | | Re: top pull dow problem Added info after reading some on line info about ground I reconnected the motor. It now seem intermittent, cycled one time and locked down ok. I released and tried to lockdown again and motor would not run. Tried to reset but would not work. Pulled on motor and bracket (unscientific) and motor ran again. Ground line looks ok. The flapper on top moves freely but does not seem to do anything. My soft top is now up for the first time. I still think this might be my elec problem. We need a spell checker option on this site |
09-26-07, 01:19 AM
|  | Cadillac Owners Enthusiast Cadillac(s): Is one enough ? | | Join Date: Jun 2003 Location: So CA | | | Re: top pull dow problem Quote:
Originally Posted by Chuck Linzey We need a spell checker option on this site | use FIREFOX, it is built in ... |
09-26-07, 08:34 AM
| | Allantesource | | Join Date: Jun 2004 Location: West Palm Beach, FL. | | | Re: top pull dow problem If pulling fuse 8 takes care of the battery drain, then the problem is probably a lock cylinder switch on the back of one of your outside key lock cylinders. This switch normally send wakeup voltage to the BCM when you unlock the car. But if it fails on, the voltage is constantly on, and this will result in a 2-3 day battery drain. I am having a little trouble following what's going on with your rear pulldown. You can call us at 561-844-3938 to discuss and we'll see if we can help you through it. |
11-10-07, 11:10 PM
|  | Cadillac Owners Fanatic Cadillac(s): '97 STS, | | Join Date: May 2003 Age: 63 | | | Re: top pull dow problem Here is a link that might help you understand the pull down motor and its components. http://dana60.com/rickko/allante/pulldown/ |
11-11-07, 06:40 PM
| | Cadillac Owners Member Cadillac(s): Cadillac Allante 1988 | | Join Date: Dec 2006 Location: Towson MD Age: 63 | | | Re: top pull dow problem You don't have permission to access /rickko/allante/pulldown/ on this server.
tried to connect |
11-12-07, 02:58 AM
|  | Cadillac Owners Fanatic Cadillac(s): '97 STS, | | Join Date: May 2003 Age: 63 | | | Re: top pull dow problem Oops, the server seems to be down. Actually, there has been some work done to it, possibly an upgrade, and now those files are missing.
I've contacted the sysmgr. We'll see if they are recovered in the next few days. If no joy by Wednesday, email me again and I'll figure out how to get the info to you or make it available again.
Thanks for letting me know.
..rickko.. |
11-15-07, 11:14 AM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac STS4 ISG PKG | | Join Date: Sep 2007 Location: tampa, florida Age: 59 | | | Re: top pull dow problem ah, i think i found my problem.it was due to ignorance(lack of knowledge).in my owners manual page 105,it's right there in my face.i was not operating the pull down switch under the cover lid. i will put it to test this weekend when the top comes back from the painter. thanks all.
11-15-07, 11:33 PM
|  | Cadillac Owners Fanatic Cadillac(s): '97 STS, | | Join Date: May 2003 Age: 63 | | | Re: Top pull dow problem Here is the correct link: http://dana60.com/rickko/allante/pulldown/Pulldown.html
I don't know how to edit my original post. It seems once you post you can't edit it, right? Oh well
..rickko.. |
01-08-08, 11:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: top pull dow problem I had ordered the housing via the part number you gave, but it's the wrong one! In looking up that part number on GM direst it comes up as the truck housing. Do you have the right part number the top pull-down housing?
Monte |
01-09-08, 02:32 AM
|  | Cadillac Owners Fanatic Cadillac(s): '97 STS, | | Join Date: May 2003 Age: 63 | | | Re: top pull dow problem I don't see "Truck" housing in this search results. Don't know why you do.
Sorry, I don't have my parts book any longer but I do know if you go to any GM dealership they can look it up for you. Take the part number I listed and ask them if its the right one for what you want.
..rickko.. |
09-08-08, 12:44 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 91 Allante, 06 SRX (gone) | | Join Date: Jun 2003 Location: Michigan | | | Re: top pull dow problem Rickko, do you still have a link with the pics? My convertible pulldown has decided to stop rising. |
09-08-08, 12:54 PM
|  | Cadillac Owners Fanatic Cadillac(s): '97 STS, | | Join Date: May 2003 Age: 63 | | | Re: top pull dow problem |
09-08-08, 01:28 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 91 Allante, 06 SRX (gone) | | Join Date: Jun 2003 Location: Michigan | | | Re: top pull dow problem I'm not seeing any pics. |
09-08-08, 10:10 PM
|  | Cadillac Owners Fanatic Cadillac(s): '97 STS, | | Join Date: May 2003 Age: 63 | | | Re: top pull dow problem I do. Try another browser. I use Firefox. Even though, I see pics using IE 7 as well.
Do you see the text?
..rickko.. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
