cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, Erratic Timing on 472 in Cadillac Engine Technical Discussion; I tried to set my timing. The timing mark was jumping around all over the place. I mean A LOT, ...
    Brother_B's Avatar
    Brother_B is offline Cadillac Owners Fanatic
    Automobile(s): 1969 Coupe DeVille, 1972 Sedan DeVille
    Jan 2007
    Neptune Beach, FL
    39
    160
    I tried to set my timing. The timing mark was jumping around all over the place. I mean A LOT, not just dancing around near the notches. I mean it was jumping everywhere visible on the pulley, and probably was on the far side of the pulley when the light flashed, at times. What can cause this?
    I have the points-style distributor. I did have the vacuum advance disconnected while trying to set timing. So far my guesses are timing chain, or bad plug wires, or I have spark jumping around in the distributor, or some kind of interference picked up by the inductive pickup on the timing light.
    Engine is running rough, very difficult cold-starting. I recently replaced the carburetor, so that is partially responible for the roughness. I want to set the timing before I make final adjustments to the carb.
    Any help appreciated! Thanks, B
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    49
    1,619
    Re: Erratic Timing on 472
    Check all primary ignition wiring connections. Borrow a diferent timing light. Try another set of points and condensor. Make sure mechanical advance works properly. A bad timing chain might make the flicker wander a little but not like you have described IMHO.
    ja70cad is offline Cadillac Owners Member
    Automobile(s): 70 Coupe DeVille
    Jan 2007
    Salinas, Ca.
    3
    I would seriously take a look at your timing chain, especially if it's never been changed... Believe me, I learned the hard way!! The old timing gears were made of nylon and once they begin falling part, watch out! You can sometimes see the pieces of nylon in the oil too.
    Good Luck, Bro...
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    BodybyFisher's Avatar
    BodybyFisher is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Deville
    Dec 2003
    Long Island, NY
    143
    Quote Originally Posted by ja70cad View Post
    Good Luck, Bro...
    Good advice, I have changed them on 390, 429 and 472 caddy engines I was always amazed that they were fiber.
    If that is not your problem check the distributor gear and the bushing near the points. I have seen this problem in a 429, but I cant recall if it affected the timing or the dwell.. Also check the centrifical advance for the springs...they springs may be weak, and check the vacuum advance for leaks..
    Brother_B's Avatar
    Jan 2007
    Neptune Beach, FL
    39
    160
    Thanks everybody for the input. I replaced plug wires and points/condenser. Once I replaced the points/condenser, it wouldn't run anymore. I was unsuccessful setting the point gap / dwell. (Gap measurement was difficult with my set-up, and the car needs to be running to set dwell.) So I decided to go ahead with the HEI distributor - I was going to anyway. I ordered one, and am waiting for it to get here. I hope that will fix all my problems (?). Next project may be a timing chain. I am hoping that at least the new distributor will allow me to actually read the timing clearly. Thanks again for the input, and I'll let you know what happens.
    Now I just need to figure out which wire will give me 12V. Maybe the new distributor will come with good instructions.
    Thanks again for helping out a noob.
    Dec 2003
    Long Island, NY
    143
    Make your job easier by bringing your #1 up to TDC and mark the position of the body of your distributor and mark where the ROTOR is pointing so that you get it back in relatively the same place.....
    Sasquatch's Avatar
    Sasquatch is offline Cadillac Owners Fanatic
    Mar 2004
    Bluff Creek
    327
    Check out this link it will tell you all you need to know. I changed my 1969 472 Cadillac Hearse to an HEI from a 74 Caddy and love it. Pay particular attention to tip #2. A relatively cheap part that made a huge difference as far as detonation (pinging). Also when possible run premium. Here's the link.
    http://www.oldengine.org/unfaq/hei.htm
    Brother_B's Avatar
    Jan 2007
    Neptune Beach, FL
    39
    160
    Thanks Sasquatch. That's funny, I had just found your link this morning looking for good info on how to replace the resistor wire. I am feeling pretty good about the wiring part now. I received my DUI HEI distributor yesterday, and tried to make this swap this evening. First snag: My old distributor refuses to come off! I guess it's just been on there so long that gasket has glued it on? Or maybe it was installed with no gasket and it's rusted on? What the heck? I am trying to devise some kind of puller. (I guess they actually make them, I have discovered.)
    Regarding Tip #2, looks like I have a 15* vacuum advance can.
    Which brings me to my next question, for anyone that might still be reading this thread: I am very curious about Thought #1 at Sasquatch's link: Manifold vs. Ported vacuum for vacuum advance. Any thoughts? Vehement opinions? Straight-up knowledge? If I use manifold vacuum for advance, do I need to change vacuum cans? I have read some persuasive arguments for using manifold vacuum for advance. Here's one link:
    http://www.hotrodders.com/forum/dist...1-a-59033.html
    B
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
