| 500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines. | Cadillac Forums: spark plug mystery
01-26-07, 10:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | spark plug mystery i have heads off of a v864. there are funky spacers or something between the plugs and the block. does anyone know if these are factory. or what they are for? help please soon |
01-27-07, 02:29 AM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: spark plug mystery Quote:
Originally Posted by eldrewado i have heads off of a v864. there are funky spacers or something between the plugs and the block. does anyone know if these are factory. or what they are for? help please soon | Spark plugs made before the now common tapered seat variety had gaskets.
__________________ Don't mess with Binky Bear! |
01-27-07, 10:21 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: spark plug mystery no these are huge. mabey spacers is a bad word, more like sleeve tunnel things. ill try to get a picture i hope theyll let me post it |
01-27-07, 11:34 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: spark plug mystery Bushings? |
01-28-07, 11:11 AM
| | Cadillac Owners Fanatic Cadillac(s): 1976 FLEETWOOD brougham | | Join Date: Jan 2005 Location: northern sweden Age: 37 | | | Re: spark plug mystery hello.
I have no experiance with the V8-6-4 engines so i dont know if it schould be anything special things there but if not: The things that are there are maybe anti fauling spacers.
They are used on engines were the plugs gets so oily that they fauls. Instead of fix the real problem with pistongrings or/and valve shafts guidings you can, as a quick fix put those spacers at the fauling cylinders and the sparkplugs keeps clean longer.
That are recomended to not use those spacers to more than half the cylinders on a engine.
Jolle |
01-28-07, 11:23 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: spark plug mystery Maybe they are heat shields. |
01-28-07, 10:55 PM
| | Cadillac Owners Fanatic Cadillac(s): 1985 Fleetwood Brougham 1996 Cadillac Fleetwood Brougham | | Join Date: Nov 2004 Location: Harrisburg, PA Age: 37 | | | Re: spark plug mystery Sounds like heat shields (see attached, no it's not on my Caddy, but it sounds like what is described) I've only seen these on newer engines.
Reason: typo
01-29-07, 12:30 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: spark plug mystery nope thats not them. i need a picture ill have one soon. btw is that a fiero gt? |
01-29-07, 01:38 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '68 DeVille (Resto'd) '95 FWBrougham '96 Ram 2500 4x4 12v | | Join Date: Mar 2004 Location: Rochester, NY Age: 23 | | | Re: spark plug mystery Let me guess... the plugs thread into this spacer and the spacer threads into the block. These are called plug de-foulers. The de-fouler is essentially a seperate chamber in which the gases flow in through a small hole at the block end of it... the plug sparks... ignites gases in chamber... in turn ignites gases in cylinder. They do work in the matter of keeping your plugs clean but they are a huge performance draw, manufacturers themselves recommend not to install on more than half of the engine's cylinders.
REMOVE THEM! |
01-29-07, 07:04 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: spark plug mystery yeah no one has said these things are stock they must be the de foulers. im gonna take em off and if the seals are a little bad and it leaks a little ill just put in oil stabiliser and that should work ok. its worked for me before, in fact ive always heard to fix a little oil burning with the oil, not the plug untill now. although i hope they arent messed up real bad because im still cleaning the sludge off of these heads.
well see what happens. thanks guys. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
