| 500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines. | Cadillac Forums: Will Eldorado 500cid engines fit in RWD Fleetwoods?
01-26-07, 05:00 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Had to go bigger: '00 Silverado 3500 Crew 4x4 with the 454. | | Join Date: Apr 2006 Location: Texas A&M | | | Will Eldorado 500cid engines fit in RWD Fleetwoods? I'm not too familiar with the seventies Cadillac engines that were front-wheel-drive, but since an early 70's Eldorado was not a transaxel, can the engine fit in a big Fleetwood Brougham? I'd like to put a 500 in my '90, but am I limited to other Devilles and Fleetwoods? Maybe the engine would fit, and I could get another tranny? Hmm? |
01-26-07, 05:43 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1970 Sedan DeVille, 2000 Grand Prix GTP, 1991 Dodge Ram W250 | | Join Date: Jul 2005 Location: BC, Canada Age: 21 | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Both RWD and FWD 500s and 472s (and 425s) were all the exact same, and should be completely interchangeable. |
01-27-07, 12:51 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Only difference I remember is in which hole the dip-stick uses, and the pan/oilpump pickup. |
01-27-07, 07:03 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1970 Sedan DeVille, 2000 Grand Prix GTP, 1991 Dodge Ram W250 | | Join Date: Jul 2005 Location: BC, Canada Age: 21 | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Oh yeah, the oil pan could be different now that I think about it, not sure on that though. |
01-28-07, 02:53 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 93 SDV, 94 Fleetwood Brougham (sold), 90 Brougham (sold) | | Join Date: Jan 2005 Location: Eagan, MN Age: 24 | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? What about the exhaust manifolds? |
01-28-07, 06:56 PM
|  | Cadillac Owners Member | | | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Actually, all of the Eldo's in the 70's were fwd/transaxle... |
01-29-07, 03:41 AM
|  | Banned Cadillac(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII | | Join Date: Aug 2003 Location: Albuquerque, NM Age: 22 | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? To put a 500 in your 90, IIRC you'd need a mid sump pan and matching pickup. If you get an Eldo motor with the rear sump, sell it for $120, buy a mid sump for $40. I don't know about the accessory drive on a 90 but a junkyard 77-81 will have the accessories/pullies you need if you find you need to change setups. |
01-29-07, 11:19 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Had to go bigger: '00 Silverado 3500 Crew 4x4 with the 454. | | Join Date: Apr 2006 Location: Texas A&M | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Well, I do have access to an '81 Fleetwood Brougham. Could I harvest it for the parts for my '90? Also will the '81's 3-speed hook up to the 500? Or can I use the tranny on my 307? Or can I use the eldorado's tranny? |
01-30-07, 08:26 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 1970 Sedan deVille hardtop | | | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? The Eldorado's transaxle is FWD only, leave it.
If the '81 Fleetwood is a 368ci, you'll need the oil pan and oil pump pickup (to match the pan) and the exhaust manifolds.
Actually, bnefore you go swapping oil pans, see where your crossmember is! If your current engine has a rear sump, then chances are that you will NEED the Eldorado oil pan/pickup, NOT the one from a RWD Cad. RWD Caddies had a front sump, but many later GM's used a rear sump. (thus why the rear sump pan costs more - more demand)
The 307 is the Olds motor? If so its trans would have the right bolt pattern, but is too weak in stock form to handle a 500ci long term. If the trans is a 200-R4, then look into building it up if you have the budget. Thanks to the turbo Buick guys those trannies have alot of hard parts made for them and can be built for the job.
You can also get a TH400 from a '70's RWD Caddy but that would lack overdrive.
I notice you plan to keep it carb'd - do you have a smog test in your area? If so that will not fly. |
01-30-07, 03:10 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Had to go bigger: '00 Silverado 3500 Crew 4x4 with the 454. | | Join Date: Apr 2006 Location: Texas A&M | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? But are you sure the Eldorado is a transaxel? The engine is not sideways. I looked under the hood and the block is parallel to the chassis just like any RWD car, but the transmission is just different to make it FWD. It wraps around under the block from what I could see. And I have seen other 80s Fleetwoods with 500cid engines from Eldorados; this guy did it: 1981 Fleetwood with an Eldorado's 500
Anyway, what's the trouble with keeping it carburated? I think I can just put a some emissions fluid in the gas just before inspection. Besides, can an engine be converted to fuel injection? - feasibly? |
01-30-07, 06:40 PM
|  | Cadillac Owners Member | | | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? The way an engine sits does not mean it has a transaxle or not. It all has to do with the way the transmission transfers the power to the wheels. My 1975 Eldo engine sits front-to-back but it is still is front wheel drive and has a transaxle. |
01-31-07, 02:27 AM
|  | Cadillac Owners Connoisseur Cadillac(s): Had to go bigger: '00 Silverado 3500 Crew 4x4 with the 454. | | Join Date: Apr 2006 Location: Texas A&M | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? So transaxel refers to the transmission, right? That would mean that the block, however, is still like the RWD machines, right? After all, I would hook up a different transmission. |
01-31-07, 05:42 AM
|  | Banned Cadillac(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII | | Join Date: Aug 2003 Location: Albuquerque, NM Age: 22 | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Transaxle is a combination of the words transmission and axle... it serves as both the transmission and the differential/axle. All 500/472/425/368s will fit where any 500/472/425/368 was before, no matter what car (there are minor exceptions like exhaust manifolds or valvecovers that aren't anything to worry about.) |
01-31-07, 09:34 AM
| | Banned Cadillac(s): 87 T-Bird with 500, Also I part out 71-78 Eldos & sell Parts | | Join Date: Jun 2006 Location: Olympia WA Age: 49 | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? If you want to put a 500 from an Eldorado in to a Deville/Fleetwood that came with a 472 or 500, ie 68 to 76 or a little later with a 425. It is a direct swap. All you have to do is change the oil pan, Driver's side exhaust manifold, starter, and motor mounts.
But putting one in a 90 that I think came with a 307 olds would be a completely different story. This is an engine swap and would be no different than putting a 500 in a Mustang or G-body, you have to design everything as you go.
Even though some 500 came with FI, it would not be easy or cheap to convert one.
TED |
01-31-07, 01:08 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 1970 Sedan deVille hardtop | | | | | Re: Will Eldorado 500cid engines fit in RWD Fleetwoods? Quote:
Originally Posted by My_favorite_Brougham Anyway, what's the trouble with keeping it carburated? I think I can just put a some emissions fluid in the gas just before inspection. Besides, can an engine be converted to fuel injection? - feasibly? | If your state inspection includes emissions they probably do a visual check for the emissions equipment. That means that you've gotta have all the original stuff that came on *your* car. Pretty sure that includes the EFI system. You might be in for a bit of a scuffle with the 500ci itself. EPA rules only allow an engine to be swapped into a car if the chassis originalls could have had that 'class' of engine. I'm pretty sure that '90 Caddys only came with smallblocks and the 500ci is a big block so "by the book" this is an automatic fail from the get-go. Technically these rules apply to everyone but it really comes down to your local laws. Where I live there is no inspection, so the Government is none the wiser about anything, but in most metropolitan areas they are likely to give you some trouble. You've also got to think: does the inspector even know what engine he is looking at?
Putting EFI on any engine is very feasible. All you need is an ECU, some sensors, injectors and a manifold that mounts the injectors instead of a carb. You've already got most of what you need on your car since it should be EFI. The GM ECU's are pretty throughly hacked so I'd bet that you can re-tune the computer you've got to run the 500. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
