Results 1 to 4 of 4
Thread: A/c Not Working Right 78 Deville
    Mar 2004
    central california
    37
    127
    Question A/c Not Working Right 78 Deville
    hello everyone
    Ive got a a/c problem in my 78 deville,
    what happens is when you are driving the car with the a/c on
    it will run ice cold and then will get warm and uncomfortable ,
    I don't think its low of freon,(no visable leaks,newer a/c delco compressor A/6)
    plus when it works it will freeze you tail off!!!
    So if any one out there know what the problem could be please reply to this thread
    thanks , tripleyellow78cad
    Jul 2003
    San Clemente, CA
    30
    989
    Re: A/c Not Working Right 78 Deville
    It's a vacumm leak somewhere probably behind the dash somewhere. My Z does that too. It'll run ice cold until you give it a certain amount of throttle then it gets warm.
    Mar 2004
    central california
    37
    127
    Question Re: A/c Not Working Right 78 Deville
    Quote Originally Posted by MMNineInchNails
    that was my thought too,
    i was thinking of adding an inline check valve but i can't find the vacume line/hose that goes in to the climate control , any idea where i can locate it?
    and if a check valve wont work what about adding an eletric vacume pump?
    thanks for you reply
  5. #4
    Mar 2004
    central california
    37
    127
    well i un pluged a set of wires on my programmer (behind the glove box)
    and the a/c blows cold all the time and never warms up, hope i wont damage anything,
    now when you move the climate control to 85 it stays on a/c
    well if i break it at least i had cold a/c for a while
  • You may not post replies
