1969 Deville idle
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 1969 Deville idle in Cadillac Engine Discussion; Hi problem: rough shaky idle recent fixes: rotor, cap, wires, plugs, Pertronix ignitor, coil, timing set to stock 5 BTDC. ...
    69DVC's Avatar
    69DVC is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Oct 2006
    Dublin, Ireland
    100
    1969 Deville idle
    Hi
    recent fixes: rotor, cap, wires, plugs, Pertronix ignitor, coil, timing set to stock 5 BTDC. Carb seems okay, reading Doug Roe's book at the moment
    Any ideas??
    Cheers
    Jon
    Ireland
    cadillacdeville's Avatar
    cadillacdeville is offline Cadillac Owners Fanatic
    May 2004
    Longview Tx
    31
    250
    Re: 1969 Deville idle
    vacuume lines maybe one cracked?
    jk1000 is offline Cadillac Owners Member
    May 2004
    tx
    90
    I'm thinking vacuum leak too. Check the entire pvc line especially where it connects to the carb. Often this hose cracks, but the crack is not visible because the a/c compressor is in the way.
    If no vacuum leaks are found, try advancing the timing a little and see if it helps.
    Hope this helps.
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    Check the vacuum advanc cannister as well. Not uncommon for the vacuum diaphragm to rupture and cause a vacuum leak.
    After that, I'd check out the carb again, make sure the idle mixture is good and maybe raise the idle RPM a bit.
  7. Remove Advertisements
