Results 1 to 10 of 10
Thread: connecting rods
    Aug 2006
    SE Michigan
    32
    27
    connecting rods
    I'm thinking about going with the 10:1 compression pistons from cad company for the 500 im building. for thoes of you who have built these engines would you trust the stock rods at this compression or do I need to buy forged?
    Jul 2005
    29
    1,221
    Re: connecting rods
    Well my 472 is 10.25:1 and its stock (1970). I'm almost positive your stock rods are fine.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: connecting rods
    I'd definitely trust the stock rods just fine at 10:1 if the rest of the motor is stock.
  5. #4
    Aug 2006
    SE Michigan
    32
    27
    Re: connecting rods
    thanks guys, but I just bought the "500" off the guy and got it home and checked the numbers turns out it's a 1970 472. I know I should have checked the numbers first but I couldn't pass it up for $140. anyway is the crank the only thing I would have to swap to make it a 500? i know the difference in performance between the two is negligable, but there's something about being able to say I'm running a 500cid caddy in my jeep. thanks for your help.
  6. #5
    Mar 2006
    26
    111
    Re: connecting rods
    Quote Originally Posted by pdoke2003 View Post
    i like the 472 better then the 500 and the 472 has 10.5 compression.i think all u have to do is change the crank to a 500 crank then u will have a 500 but im not really sure.
  7. #6
    Nick Campagna is offline Cadillac Owners Member
    Automobile(s): 1976 Eldorado convert
    Sep 2004
    17
    Re: connecting rods
    If you change the crank, you must change the rods, OR pistons to maintain the same compression height. Check out EGGE.COM for original cast 1970 500 pistons.
  8. #7
    Aug 2006
    SE Michigan
    32
    27
    Re: connecting rods
    thanks, I actually just found that out today searching around this site. now I just need to find a cheap good crank. the junk yards around here are useless and the best price I've found so far is $200 from MTS(500cid.com) but I'm not looking forward to shipping from california. That EGGE site is great, I had never seen that before, and I'll probably buy pistons from them but they don't see cranks. So if anyone out there has a 500 crank they want to get rid of or wants to buy a 472 crank for $200 let me know. I live in michigan.
  9. #8
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: connecting rods
    For the price Egge wants for cast pistons I'd just go for KBs..
  10. #9
    Aug 2006
    SE Michigan
    32
    27
    Re: connecting rods
    the only problem with that is KB doesn't make 10:1 pistons for a 500 with 76cc heads. then I'm back to 12.5:1 compression and I have to worry about racing gas and possible connecting rod breakage.
  11. #10
    Aug 2006
    SE Michigan
    32
    27
    Re: connecting rods
    nevermind I just found them from cad company for 395.
  • You may not post replies
