Camshaft
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, Camshaft in Cadillac Engine Discussion; Does it matter if a put a camshaft from a 472, 1968 high comp into my 500, 1974 low comp ...
    caddyswede's Avatar
    caddyswede is offline Cadillac Owners Member
    Automobile(s): Cadillac deVille sedan HT-68
    Sep 2005
    Sweden
    52
    Camshaft
    Does it matter if a put a camshaft from a 472, 1968 high comp into my 500, 1974 low comp engine? Better or worse? Thank's for comment's.
    http://www.cardomain.com/ride/690250
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Camshaft
    It would work but wouldn't make a noticeable difference IMO. If you must run a stock cam, advance it a few degrees.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,264
    Re: Camshaft
    Quote Originally Posted by davesdeville View Post
    Advancing cam timing improves the bottom end and idle. Retarding cam timing improves the top end performance.
