Results 1 to 4 of 4
Thread: Blown 472?
    Jul 2006
    Blown 472?
    Hi, First post and I did search/read for about an hour.
    I was wondering if anyone has supercharged or turbocharged their 472 (or even 500). I am looking to turbocharge one, and I have read several books and couple of sites on turbocharging. I plan on replacing/beefing up everything except for the crankshaft, which I saw for $2600, which is kinda expensive for a kid like me. How much power has anyone put it through and have it last for more than 5min?
    Also, I would have to convert the engine to EFI. Has anyone tried the "universal" kits, or did you just build it up yourself.
    Thanks for your time
    Ryan
    1987olds442's Avatar
    1987olds442 is offline Cadillac Owners Member
    Automobile(s): 1972 Eldorado, 2002 DTS, 507 Caddy Powered Oldsmobile 442
    Jan 2005
    Washington County, VA
    40
    31
    Re: Blown 472?
    Potter's Automotive may be able to answer your questions...
    Potter Automotive
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Blown 472?
    You don't need to replace the crank. Maybe if you're running 30psi through a wild cam you would...
    Copper gaskets and an O-Ring would be a good investment, along with the usual forged pistons and rods and shaft rockers...
    There happens to be a 472 based Maliboo running around. IIRC it uses a 472 crank, revs easier. It's got a blower, and makes around 1400hp.
  5. #4
    Jul 2006
    Re: Blown 472?
    Thanks for the quick replies, I'll give Potter a ring
  • You may not post replies
