Engine coolant was leaking from the driver side
Results 1 to 11 of 11
500, 472, 425, 368 Discussion, Engine coolant was leaking from the driver side in Cadillac Engine Discussion; I just got off the road, pulled into the parking lot and heavy steam was coming from under the hood. ...
    Tyrannous's Avatar
    Tyrannous is offline Cadillac Owners Member
    Automobile(s): 1973 cadillac sedan deville
    Nov 2005
    D.C.
    34
    38
    I just got off the road, pulled into the parking lot and heavy steam was coming from under the hood. Engine coolant was leaking from the driver side/mid-rear engine area... i pushed it when i got off the highway and i heard a little thump, dont tell me i just did what i think i did, crack the engine block.... please help im crying inside. thoughts?
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Re: ....
    from our rules
    "No profanity in subject lines, signatures or posted messages."
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    Tyrannous's Avatar
    Nov 2005
    D.C.
    34
    38
    Re: ....
    thanks for your help.
    check out the video....
    YouTube - cadillac coolant spill
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: Engine coolant was leaking from the driver side
    Can't really see much from the video, but I would guess that you've lost a freeze plug.
    Ted in Olympia is offline Banned
    Automobile(s): 87 T-Bird with 500, Also I part out 71-78 Eldos & sell Parts
    Jun 2006
    Olympia WA
    56
    70
    The terrible one is right. They make expandable rubber ones that will replace the original. Just take out the old one and put in the new one and tighten down the nut in the middle. You can buy them at your local parts store.
    Good luck
    TED
    kevin666's Avatar
    kevin666 is offline Cadillac Owners Member
    May 2006
    49
    What profanity? Am I missing something?
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    I'm guessing the "..." used to contain other characters.
    Can't see the video because youtube is blocked on the computer I'm on. But, if it is a freeze plug, you ought to be able to reach down there or crawl under the car and look on the side of the block for a smooth round hole about 1/2 dollar sized or so, maybe larger. Freeze plugs are round metal plugs hammered into the side of the block to fill the holes left by parts of the casting process.
    How's the coolant level? If the whole plug popped out, you will have lost most of your coolant and the radiator will look empty. It is also possible that the plug is just leaking and spraying coolant on the exhaust manifold, making tons of steam.
    Either way, it's something you need fixed because coolant leaks are a great way to overheat and kill a motor. Any competent repair shop can handle it, or DIY if you're inclined.
    Tyrannous's Avatar
    Nov 2005
    D.C.
    34
    38
    the title was f word with the vowel starred out, guess that was too raw?
    @blueyes: coolant is all gone.
    anyways, thanks everyone for the great response as always!
    thanks for the DIY specifics!
    Tyrannous's Avatar
    Nov 2005
    D.C.
    34
    38
    just an update, THANKS SO MUCH "TERRIBLE ONE" here is a picture of the problem, then a picture of the removed plugg (after some grunt work). now i have the plug removed, and no good vantage to knock in the new plug... so ill take care of that in a day or two
    Jun 2006
    Olympia WA
    56
    70
    Put in the rubber one, it will be very easy.
    TED
    74eldog is offline Cadillac Owners Fanatic
    Automobile(s): 74 Eldorado
    May 2005
    Columbus, Ohio
    149
    anything has to be easier than those metal ones.... When i put them in my SBC it was a trip and the motor was on the stand....lol
  14. Remove Advertisements
