Results 1 to 7 of 7
Thread: Rear Ends
    Clinton is offline Cadillac Owners Member
    Automobile(s): Cadillac, 1972
    Aug 2006
    Las Vegas
    1
    Cool Rear Ends
    Hi, I'm new to the forum.
    I Race a 1972 Cad, 500, in the Bomber Class. This class is restriced to 355 rear ends or less. Anyone got an idea how close I can get to that 355 and where. I appear to be running something around 242 at the moment and was ok on dirt as dirt is more driver than car. Not so on asphalt. I need to get more speed/acceleration out the the car but stay within the rules.
    I am not a mechanic and I just recently (today) acquired the car after racing it last night on a dirt track. I am planning on racing it here in Las Vegas on asphalt in the next couple weeks and need more quick acceleration coming out of the turns. Bomber class is strick on some types of improvements and 355 it tops for rear ends.
    Any help would be appreciated..
    Thanks
    linearone is offline Cadillac Owners Member
    Automobile(s): 1981 coupe deville 6.0 liter
    Aug 2006
    23
    Re: Rear Ends
    I dont know if cadillac rear ends are special or not from the others put out by big 3 but I would try Randy's ring and pinion first. They do seem to have everything.
    Randy's Ring & Pinion - Your Source for Differential Parts
    hope that helps
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Rear Ends
    I'm not aware of anything aftermarket for the oddball rear these things have. IIRC my 75 has 2.73s (now if it had a posi I'd be set - the ring gear looks like it's out of a rear from a dump truck.)
  5. #4
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Rear Ends
    Some of these cars came optional with a 3.15 axle ratio. They also had optional posi. Good luck finding one. The more comonly found ratio was 2.93.
  6. #5
    Phantom&RedGoat2004's Avatar
    Phantom&RedGoat2004 is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Nov 2006
    Lufkin, Tx
    116
    Re: Rear Ends
    Service cars (such as an ambulance, funeral cars, and series 75 limo's) had better gears in them (2.93 vs. the production cars 2.56-ish). I found one with factory posi, but that was a very rare find from what I understand. The rears are diferent from the other GMs, so you would have to stay Caddy, and you would have to get a post-'69 car to keep the guts to fit in your housing. I had this swap in my '71, and it made a big diference. Hope that helped, PRG04
  7. #6
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    30
    857
    Re: Rear Ends
    Quote Originally Posted by Phantom&RedGoat2004 View Post
    These rearends are a restorationists worst nightmare. I cant find one place that carries ring and pinion gears for these, bearings and seals are an easy find however.
  8. #7
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Rear Ends
    Quote Originally Posted by JTraik View Post
    There is no market for replacement parts because they simply don't fail.
  • You may not post replies
