Shifter Issues
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, Shifter Issues in Cadillac Engine Discussion; I have a 77 Eldorado with a 425 engine, and Th-425 transmission. It seems that lately it's difficult to "shift' ...
    JacobEldorado is offline Cadillac Owners Member
    Nov 2003
    6
    Shifter Issues
    It seems that lately it's difficult to "shift' into the right gear ie from park to drive. The lever seems sloppy and doesn't ratchet. The gear "pointer" also doesn't line up well with the "P R N D" letters.
    Otherwise the car drives great.
    Is there a simple way to adjust this myself, or should I have a transmission shop make this adjustment.
    I get nervous around transmissions, and I don't want to screw anything up.
    thanks for the help
    Leeb's Avatar
    Leeb is offline Cadillac Owners Enthusiast
    Automobile(s): did this once... 86 Deville, 86 300E, 78 R100rs
    Jun 2005
    Palm Spgs CA
    57
    517
    Re: Shifter Issues
    You're most likely in need of the linkage bushing kit(s)...
    Cadillac PROBABLY still has them, tho I can't tell you what # to ask for...
    Otherwise, any adjustments made will just adversely affect other positions.
