1968 Deville Convertible Died
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, 1968 Deville Convertible Died in Cadillac Engine Discussion; My brother has I car that I have to help him work on. We got the brakes working but now ...
    bros68deville is offline Cadillac Owners Member
    Aug 2006
    My brother has I car that I have to help him work on. We got the brakes working but now it died. He had trouble with it overheating and installed new radiator and water pump. He was out driving and it died. It started and ran enought to limp home and has not ran since. We are getting gas and spark and seem to have compression but have not check with a meter. I am guessing timing chain. Does anyone know how to check without tearing down? Any other suggestions for trouble shooting? What about unleaded gas? Could he have burned the valves out? I am working on finding out displacement but currently not sure.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 1968 Deville Convertible Died
    How fresh is the carb, and fuel filter? You could have a rusty tank that is clogging up the fuel filter and carb. I'd check that out first, before tearing the engine open hunting a valve timing problem.
    Also, the 472's will run fine on unleaded gasoline, so that's not the problem.
    Aug 2006
    We did check for gas. Filter and all are good. I have not torn down the carb because the engine will not even fire when we dribble gas thru the carb. Could the timing chain stretch bad enough to cause a no run situation or would it have had to jump a tooth?
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    There's a chance the cam timing is really far off... I'd do a compression check just to see if something comes up. If it won't fire even with some starter fluid, I'd look at the ignition system next.
    Unleaded gas should be fine in any 472 or 500.
    Leeb's Avatar
    Leeb is offline Cadillac Owners Enthusiast
    Automobile(s): did this once... 86 Deville, 86 300E, 78 R100rs
    Jun 2005
    Palm Spgs CA
    56
    517
    Since you claim it DOES have spark, you should bump the engine over (or turn by hand) to line up the timing mark w/ TDC...
    Pull the dist cap off and check to see if the rotor is at cyl 1 or 180 out...
    (180 out could be exhaust stroke...)
    If its not REAL CLOSE to 1 or 180 you probably have lost time...
    I think you could probably use a timing light to check as well, if it's inductive... you did say spark was there... but the higher-speed rotation could be detrimental in the long run...
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Have you put new plugs in it? If not do it.
  9. Remove Advertisements
