429 help
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 429 help in Cadillac Engine Discussion; heat risers i believe they are. I have a 66 deville and coming out of the heads are 8 pipes. ...
    87cadibrome is offline Cadillac Owners Member
    Aug 2005
    7
    429 help
    heat risers i believe they are. I have a 66 deville and coming out of the heads are 8 pipes. 4 on each side. they merge into larger pipes running parallel with the valve covers? what are these? what do they do? and how can i get rid of them?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 429 help
    They sound like they are part of the air injection system, which was for emmissions. Do they eventually hook to an air pump that is run by one of the V-belts?
    Aug 2005
    7
    Re: 429 help
    not sure, they are capped at the top of the larger rails. would the original repair manual have information and pictures of this? been looking into getting one off ebay
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 429 help
    Yeah, the FSM would tell you what that was.
  7. Remove Advertisements
