Preferred 425 timing procedure
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, Preferred 425 timing procedure in Cadillac Engine Discussion; The manual has a fairly elaborate procedure for checking or setting timing on a 425 which I have used with ...
    VicVega is offline Cadillac Owners Member
    Oct 2004
    37
    The manual has a fairly elaborate procedure for checking or setting timing on a 425 which I have used with no problems.
    Is there another way to do this?
    Any idea why this procedure is used? I have my idea's why, but just curious if anybody knew for sure.
    Thanks.
    VV
    74eldog is offline Cadillac Owners Fanatic
    Automobile(s): 74 Eldorado
    May 2005
    Columbus, Ohio
    149
    Re: Preferred 425 timing procedure
    Well it's probably pretty basic, like other older vehicles...
    If you want to check your timing, get a timing light, hook it up, loosen the dist. hold down bolt a little to advance or retard to where it needs to be,fire up the engine pull the vacuum advance line off of the dist. and and point the light at the timing indicator(?) on the timing cover, behind the waterpump........
    HTH
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    The timing proceedure is different from many cars of the same era. It is that way in order to provide maximum economy. There just isn't a simple foolproof way around it.
