Any advice on this?
Results 1 to 9 of 9
500, 472, 425, 368 Discussion, Any advice on this? in Cadillac Engine Discussion; I just purchased my first caddy....a 1979 sedan deville, with a 425 4 barrel carb. 90k miles on it,,,pretty clean ...
    79caddy1's Avatar
    79caddy1 is offline Cadillac Owners Member
    Jul 2006
    PGH, Pa.
    67
    Any advice on this?
    90k miles on it,,,pretty clean car...
    It is running rough, and missing. It seems to be lacking power.
    If I have the car in park or neutral, it will rev up just fine, nice and smooth.
    When I put it in gear, it seems to be running rough when I hit the gas, like a miss and sputters up the road.. And lack of power.
    I can't make sense of it. I checked, and someone before me has put in new plugs, they look clean,. and also the wires seem fine. Gas filter is new, cap and rotor are new,..
    I just repleced the ignition module, from messing around, and pulling wires while it was running, the module blew out. I repleced it, and of course, it fired right back up, and still the sam,e problem though.
    Has anyone run into this, or have advise. Thanks so much in advance, looking forward to driving this caddy, and having a new home here on this forum,,,,Tony
    Feb 2003
    california
    69
    6,679
    Re: Any advice on this?
    Run a compression test to rule out internal engine problems. Ideally this car should be hooked up to a scope to see the firing line to rule out secondary ignition problems. If both tests are within spec then I would look for a vacuuum leak.
    79caddy1's Avatar
    Jul 2006
    PGH, Pa.
    67
    Thanks.....I should have checked for a leak, didn't think of that one.
    I was trying to keep from taking it to the machine. Is it possible to get a new bad plug or wire?
    Junkman's Avatar
    Junkman is offline Cadillac Owners Fanatic
    Automobile(s): '78 Superior Cadillac Amublance, '69 Miller Meteor Ambulance
    Dec 2004
    Northeast CT
    245
    Quote Originally Posted by 79caddy1
    .......... Is it possible to get a new bad plug or wire?
    Defective new parts are always a possibility. Check the vacuum release on the emergency brake. Seems that it is a common source of problems. Considering the age of the car, there is a possibility that any of the vacuum hoses could be cracked and in need of replacement. Also check the brake booster hose where it enters at the back of the carburetor. This is another common problem area. Junk....
    79caddy1's Avatar
    Jul 2006
    PGH, Pa.
    67
    Thanks....I checked for leaks this morning, and found nothing. Actually, it looks like somone replaced all the lines. The motor is really clean, but still missing and rough, when trying to drive it. I cannot believe how smooth it is and revs up, when out of gear.
    Sasquatch's Avatar
    Sasquatch is offline Cadillac Owners Fanatic
    Mar 2004
    Bluff Creek
    322
    Vac advance in the distributor?
    79caddy1's Avatar
    Jul 2006
    PGH, Pa.
    67
    i pulled the vac advance, and it idled down, I am wondering if the advance is working, now that you brought it up.....
    79caddy1's Avatar
    Jul 2006
    PGH, Pa.
    67
    It is fixed....The wires I bought were junk!
    I pulled number 8 plug, and it was black....I changed that plug, and put better wires on, and it runs perfect.....WOW...My first caddy....I am impressed....whatta smoooooooooth ride!
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Glad you got it figured out, enjoy the ride.
  12. Remove Advertisements
