| Re: 1971 Hearse a/c problem The blend doors are vacuum controlled - check all the vacuum lines under the dash - for starters. There's a bunch of them between the control head and the programmer (heater box).
Also check to make sure the vacuum source from under the hood is connected.
Sometimes the ports on the head or programmer get clogged-up, especially on a car that sits/has sat for a long time.
It could also be debris in the heater box (leaves, mouse nest, etc.) that prevents the blend door from moving. |
