472 or 500 Superchargers?
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
500, 472, 425, 368 Discussion, 472 or 500 Superchargers? in Cadillac Engine Discussion; I was wondering if anyone around here has or knows of anyone who has put a supercharger or a turbocharger ...
    68'Eldorado's Avatar
    68'Eldorado is offline Cadillac Owners Member
    Nov 2003
    32
    Lightbulb472 or 500 Superchargers?
    I was wondering if anyone around here has or knows of anyone who has put a supercharger or a turbocharger onto a big inch Cadillac engine? What kind of power would we be looking at there? If you were to supercharge a 1970 500ci what kind of horsepower would it be?
    agent22 is offline Cadillac Owners Member
    Feb 2004
    11
    Re: 472 or 500 Superchargers?
    go to www.procharger.com it has exellent supercharging systems with intercooler kits.they come with warranties and detailed installation instructions...if i had the money i would buy a kit for sure.they are also 50 state carb legal.i have not even heard of anything close to these kinds of offers,usually there is alot of risk,but this company gives u a lot of "peice of mind" and is a "safer"bet than most other "systems"....
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    There are a couple turbo 500 projects out there, there are 2 people over at shiftless's forum who are actively working on their projects but neither are quite done yet. When I get the money I'm going for two big T04s or a huge single on a stock or near stock 500.
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    BDS (Blower Drive Service) has a blower set-up for the BBCad.
    Vern is offline Banned
    Jan 2003
    Dayton, OH
    23
    Potter at www.cadillacperformanceparts.com builds & sells the BDS setup. Helpfull & knowledgable too. Give him a call and he can quickly fill you in on what it will cost and what it is capable of.
    Angela Desmond is offline Cadillac Owners Fanatic
    Apr 2003
    new windsor new york
    60
    193
    "Caddycarlo" is running one. Check out : http://mywebpages.comcast.net/caddyc...i%20blower.jpg
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Wow, that one blows through the stock intake? B&M still make it?
    Jan 2003
    Ohio
    47
    1,258
    I looked at B&M's site......I didn't see any.
    I'm assuming that there's some type of custom adapter used for the blower on the stock intake.
    sinverarity is offline Cadillac Owners Member
    Mar 2004
    5
    Probibly your best bet would be to use the 460 adapter plate, and look into a supercharger for a ford bb.. Just an idea..
    caddycarlo is offline Cadillac Owners Member
    Automobile(s): cad 500 engines
    Jan 2004
    42
    b-m no longer makes blowers ..... holley took weind and b-m and put them under its own name ........ since the adaptor was for the b-m case and holley went with the weind case the part went away ...... I tryed to get some before this happened but was too late ...... the adaptor with the 177 blower has run well it took a stock 8 to 1 motor from 273 hp and 447 ft lbs to the rear up to 384 hp and 520 ft lbs to the rear with 7 lbs of boost the blower can make 9 lbs on a 500 cid motor ......... the blower setup was for a pontiac motor and was used when I got it ....... b-m made lots of the adaptors so they are out there if you look but you will need the b-m blower to bolt to one ... or you could make a new adaptor for the holley blower ......... these types of blowers are also avalble from holley in a 250 cid size that would let you run more boost....... your other option for mounting the blower is a potter intake with a new top plate .....
    latter caddycarlo
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Ah well. I know what i'm looking for at the next couple of swapmeets....
    BTW, Welcome aboard! I've seen your car at the link the first picture came from, very nice!
    catman's Avatar
    catman is offline Cadillac Owners Member
    May 2004
    Caracas, Venezuela
    49
    11
    Sinverarity has about the best suggestion. get an adaptor plate for a BBF 460 and Weiand makes a kick but supercharger. put dual 4bbl and a couple Hi-Tek filter assemblies, and nice seeing you... you're gone.
    Allante North *'s Avatar
    Allante North * is offline Banned
    Automobile(s): 1993 Triple Black Allante
    Dec 2002
    Rocky Top Tennessee
    57
    701
    Saw a couple of turbos on Caddy Big Blocks this past weekend at Potters Shindig in Chattanooga, TN. Maliboo had 1147HP out of a twin turbo Caddy Big Block in a highly modified and custom Malibu. Purple inside and outside and wicked as hades. Sean brought his 1969 Coupe down from Ohio and it was One Bad Cad with a turbo. It was set up for drag racing and he had just made his first pass a day or two before the trip. It looked evil, kinda like the Lincon the cut up in Animal House. I told him he needed a skull and crossbones painted on the body somewhere. It was a Hoss for sure. I would have loved to see them line up out on the 4 lane, but cooler heads prevailed. It can be done if you have the time, patience, and the bucks. Oh yeah, some big ole nuggets might come in handy also.
  16. #14
    Apr 2003
    60
    193
    Oh, yea, right, the nuggets...Almost forgot about those, did you????
  17. #15
    Dec 2002
    Rocky Top Tennessee
    57
    701
    I don't really think the nuggets have much to do with it! More like dane bamage to light the candle on something with that much tourqe and horsepower. I think the ole nuggets might draw up and hide if I ever got a chance to drive one of those beasts. I know the pucker factor would at least go up a few notches. I think I have lost egnought brain cells over the years to give it a try, but my better half might want to make sure the the ole life insurance is paid up just in case
  18. Remove Advertisements
