Whats the firing order for a 500 and a 472
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, Whats the firing order for a 500 and a 472 in Cadillac Engine Discussion; Hello everyone, I need to know so I can check this motor out and make sure everything is in place. ...
    93sdeville4.9m's Avatar
    93sdeville4.9m is offline Cadillac Owners Member
    Nov 2003
    62
    Hello everyone,
    I need to know so I can check this motor out and make sure everything is in place. Hopefully someone can tell me. I just want to be prepared cause the motor could be a 500 or a 472. If I dont get it now Ill just be asking later. Thanks for all the help out there!
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Whats the firing order for a 500 and a 472
    1-5-6-3-4-2-7-8 Passenger side is the odd-numbered cylinders.
    Nov 2003
    62
    You are very smart. You must have a lot books. How about the distributor? Counterclockwise from the # 1.
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Counter from 1: 1-8-7-2-4-3-6-5
    Dist. rotates clockwise, and for refrence, the #5 tower is the one by the dwell adjustment window (points distributors only, I think HEI has it on a retainer or something)
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Also, if you are interested in grabbing a FSM for your car, try here: http://www.faxonautoliterature.com/ I have had good luck with them in the past.
    Nov 2003
    62
    The motor is HEI. I remember that.
  9. Remove Advertisements
