Fuel injection questions
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, Fuel injection questions in Cadillac Engine Discussion; Gentlemen, Its been awhile since I posted here. Since thelast time I was on I have managed to get my ...
    bobbyt's Avatar
    bobbyt is offline Cadillac Owners Member
    May 2005
    Albuquerque, NM
    24
    Gentlemen,
    Its been awhile since I posted here. Since thelast time I was on I have managed to get my 472 stuffed into my 49 Ford truck and its driveable. My plan is to to go with fule injection. I managed to scrounge up one of the old port injected manifolds complete with injectors, fuel rails, and throttle body.
    What I would like to do is to adapt modern electronics to the old hardware as the original computers were expensive and finicky. Has anyone messed with anything like this? I was thinking I could adapt the ECM from a late model GM vehicle with a port injected V8 to control the injectors.
    Any thoughts??
    Bobby
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: Fuel injection questions
    If I were you, I would check out the Megasquirt controllers. I've heard really good things about them, and was going to go with one myself until I decided to stick with the carb. http://www.megasquirt.info/
    Harry Covert is offline Cadillac Owners Member
    Jun 2006
    4
    I highly recomend the mega-squirt controller. I've been running one one a 53 Stude bracket car with a 500 cad for a couple of years. I can't race as much as I'd like but is is fun tuning in the pits with a laptop. I used an edelbrock manifold, I welded holley injector bungs in it. I adapted a BBK throttle body for a 460 ford truck to it. There are better ways then that tb but I run a large prostock type hood scoop so I had lots of room. I use 39lb. injectors which should be good for 500 hp but I'm not at that level yet. Have fun
  5. #4
    bobbyt's Avatar
    May 2005
    Albuquerque, NM
    24
    Thanks for the responses. I'll definatley look into the megasquirt controller. I'm inno big hurry for this its just something that I would like to eventually end up with
    thanks again
    Bobby
  6. #5
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    There are several "ready to install" setups you can buy for old carbuerated engines.
    Just shop around.
    It would likely be easier to install a "kit" than to try to piece something together from some other application.
  7. #6
    472's Avatar
    472
    472 is offline Cadillac Owners Fanatic
    Automobile(s): 55 60S, 81 DeVille (Diesel), 83 Coupe (507), 84 Wood (425)
    Dec 2004
    PDX
    33
    119
    Just a suggestion... Maybe a complete aftermarket EFI setup for BIG Ford motors (460) and a Cadillac to Ford 460 intake adapter (spendin bucks, though)
    Since you have all the factory goodies, a standalone controller is most likely a workable route
  8. Remove Advertisements
