Steel Timing Set,*Check*
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Steel Timing Set,*Check* in Cadillac Engine Discussion; Accel HEI Coil,*Check* You folks were SO GOOD on the last question we'll try one more. Valve seals and Rockers. ...
    51Cards's Avatar
    51Cards is offline Cadillac Owners Member
    Automobile(s): 1969 Deville Convertible
    Jun 2006
    Oxford, N.C.
    62
    12
    Accel HEI Coil,*Check* You folks were SO GOOD on the last question we'll try one more. Valve seals and Rockers. In your Opinion where's the best "VALUE" I do not mean Cheapest, as I do not want to replace em next week. BUT I don't want to spend more than necessary to do the job CORRECTLY.
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    Re: Steel Timing Set,*Check*
    For the valve seals, go by NAPA and pick up some Clevite brand seals - the "umbrella" style. These grip onto the valve guide and have a rubber part that seals around the valve stem.
    The rockers are going to be tough if you have the T-pedastal design. What's wrong with the ones you have? GM made this part obsolete years ago so there are no replacements available unless you can find some that have been sitting in the corner of some warehouse for the last few decades.
    The aftermarket has a number of replacement rocker systems available, but these generally require machining the head (heads must come off) and aren't cheap at all.
    51Cards's Avatar
    Jun 2006
    Oxford, N.C.
    62
    12
    Someone said I can use Ford Rockers does this include Machining also?
    BluEyes's Avatar
    Feb 2005
    595
    I've never heard of this before. Maybe someone else can chime in on it? I presume this would be just replacing the rocker arm on the t-pedastal with something from a Ford shaft rocker arrangement?
    It's not hard to unbolt one of the pedastals, you might try just getting a pair of Ford rockers from a junkyard and see if they work.
    I've never head of the Caddy rockers really wearing out though, just that the T design is unstable at higher RPM's.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Ford rockers are far from a bolt-on. You can make a shaft setup with them but unless you work at a machine shop and have some spare time there it's more effort than it's worth.
  8. Remove Advertisements
