Strange Knocking from 500 Engine- Solution
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Strange Knocking from 500 Engine- Solution in Cadillac Engine Discussion; After many diagnostics from many different 'experts', some saying big end bearing, others saying lifters, piston pins et al. I ...
    blueboy is offline Cadillac Owners Fanatic
    Apr 2005
    nashville, tn
    100
    After many diagnostics from many different 'experts', some saying big end bearing, others saying lifters, piston pins et al. I finally found an elderly gentleman in Selmer, Tennessee who had worked on these cars for most of his life and he suggested we check the flex plate or flywheel. Sure enough we found a crack and the offending part was duly replaced ...... Voila ! no more knocking sound.
    Just wanted to post this result as a help to others.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Strange Knocking from 500 Engine- Solution
    Hmmm....if those "experts" had read the service manual, I'm pretty sure it suggests inspecting the flywheel for cracks as a possible cause of noise!
    Glad you got it fixed without having to tear the engine apart!
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Was this a windowed or solid flexplate?
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    All 472 and 500s had solid flexplates. I think it was just the 425 and 368? that had the windowed ones. But I do hope he replaced it with the correct one!
    Aug 2003
    Albuquerque, NM
    29
    7,971
    I'd like to know where you got your info that the 500/472s are all solid. I have a 472 in my posession with a windowed flexplate, I've measured the stroke and I know it's a 472. It could have a different flexplate, but that would be pretty odd if it did.
  8. Remove Advertisements
