Replacement transmission progress
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
500, 472, 425, 368 Discussion, Replacement transmission progress in Cadillac Engine Discussion; I desided to make a new thread to keep everyone that wants to know updated on my progress with replacing ...
    MMNineInchNails's Avatar
    MMNineInchNails is offline Cadillac Owners Enthusiast
    Jul 2003
    San Clemente, CA
    30
    989
    I desided to make a new thread to keep everyone that wants to know updated on my progress with replacing the old, beaten transmission. I may get pictures later of the new trans.
    So far I've this is what i've done:
    Drained trans fluid(oviously), removed drive shaft (which didn't even fit in my engine locker in auto shop that can hold two engines in it. I've got half of the drive shaft in my locker and half in my friends), I've disconnected all transmission lines and wires, Removed starter, Removed flywheel cover (also bead blasted it and painted it), Removed crossmember bolts, Removed torque converter bolts.
    That's all I've done in the past month and a half because lack of Lab time. The Transmission is still in the car, but alls I need to do now it remove the bolts and take it out.
    If anyone needs pictures of anything while I'm down there, let me know.
    * also got my shift kit for the new trans and electric kickdown too.
    Dead Sled's Avatar
    Dead Sled is offline Cadillac Owners Connoisseur
    Jan 2003
    South of a Cornfield, IA
    1,380
    Re: Replacement transmission progress
    Souns like a plan. what shift kit you using? I'd highly recomend a performance rebuild kit from Hughes.
    Jul 2003
    San Clemente, CA
    30
    989
    shift kit is the tci chirp kit, i bought a new transmission (reman) so it doesn't need rebuilding.
    Jul 2003
    San Clemente, CA
    30
    989
    Heres an update on my project.
    Today I pulled the caddy onto the hoist with my Z and the caddy desided it wanted to blow out a tire, so it did. Damn heavy car and the poor Z was spinning it's tire. Finally got it on the hoist and got the Crossmember off and the Transmission is now out. I got all that I was hoping done to it today.
    Jul 2003
    San Clemente, CA
    30
    989
    4 New tires last tuesday for her.
    Started taking off everything I needed off the old transmission and putting it on the new one. I have to get the electric terminal out and onto the new trans and such. I'm hoping to complete everything by the end of April as a birthday present to myself.
    tripleyellow78cad's Avatar
    tripleyellow78cad is offline Cadillac Owners Fanatic
    Mar 2004
    central california
    38
    127
    Quote Originally Posted by MMNineInchNails
    well i hope you do finish that tranny by your birthday
    nothing like a good tire melting burnout for ones b-day
    and have you thought about a a trick torque converter?
    now dont quote me on this
    but i heard that some 1965-66 buicks had variable pitch torque converters
    that you could lock up electriclay via a switch
    i found this info about that torque converter at the following web link
    http://www.novak-adapt.com/knowledge/th400.htm
    variable pitch stator feature of the Turbo 400 was available in 1965-1967 Buick, Olds and Cadillacs. These are identified by the two-prong plug on the case. While 1970-1974 models also had this plug, it is for the transmission controlled spark system. that is some of what they say on their site
    also their is a good pontiac website that talks in detail aout this torque converter their web link is also listed below
    http://www.pontiacstreetperformance..../Twisting.html
    i hope this helps and good luck:coolgleam
    Jul 2003
    San Clemente, CA
    30
    989
    I have a brand new torque converter.
    Jul 2003
    San Clemente, CA
    30
    989
    Shift kit installed today. Friday I'll be wiring up theelectric kickdown then next Wednesday I'll have the tranny in the car. First place I get to go is the gas station, then wash it, then off to pimp mass ladies.
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Finally! How are you plumbing this thing? I hope your not using the old cooler in the radiator, as it's probably filled with bits of the old trans. Also, try and borrow a camcorder, we want burnout movies! :coolgleam
    Jul 2003
    San Clemente, CA
    30
    989
    Got my hayden high performance external tranmission oil cooler 10"x 15 1/2"
    Jul 2003
    San Clemente, CA
    30
    989
    Successfully installed the transmission oil cooler today and got yelled at by the janitor about how my teacher wasn't there blah blah how does he know it's my car. I just told him I have the pink slip and my school ID card and he's like fine whatever and left. haha.
    Everything's ready for the big wednesday. 4 more days til the tranny goes in.
    Jul 2003
    San Clemente, CA
    30
    989
    So Tomorrow is the big day. My auto teacher said I can't do it and finish it by tomorrow. I'm planning on proving him wrong. I'll have about 4 hours to put the new tranny in and bolt it down and get the mount and crossmember in there and drive shaft and lines hooked up. It took me one 2 hour period to get it unbolted and out and another 2 hour class period to get the drive shaft and all the lines and crossmember out. Maybe even some after school work and working until it gets dark but I am really hoping to drive it home tomorrow.
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Damn, good luck. Sounds possible, but it is still a solid days worth of work. Don't forget the victory burnout lap...
  16. #14
    Jul 2003
    San Clemente, CA
    30
    989
    Quote Originally Posted by DaveSmed
    Yep all the way from auto shop to the street then onto another street.
  17. #15
    Jul 2003
    San Clemente, CA
    30
    989
    Just got home. I got the new transmission bolted in, torque converter bolted on, crossemember bolted on, driveshaft on, flywheel cover halfway on. EVERYTHING!!! But my auto teacher was such a dick and wouldn't let me stay after school to tighten up TWO bolts for the starter. TWO BOLTS LEFT. JESUS ****ING CHRIST. Alls I have left are those two bolts and shift linkage. JESUS. tomorrow morning i'm finishing it up though. I bet my auto teacher 50 points that i could get it running today and I'm thinking the only reason he didn't let me finish two bolts were beceause he didn't want to give me the points. What a dick.
  18. Remove Advertisements
