can seafoam mess up my motor
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, can seafoam mess up my motor in Cadillac Engine Discussion; ok its been 3 days it runs like shit after i put the seafoam shit down the carb yes i ...
    1969cadillaceldorado's Avatar
    1969cadillaceldorado is offline Cadillac Owners Fanatic
    Mar 2006
    27
    111
    ok its been 3 days it runs like shit after i put the seafoam shit down the carb yes i might of put a little to much down the carb was trying to kill it but now it wont idle cant really rev it so what should i do?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: can seafoam F up my motor
    pull out the spark plugs and look. They might be loaded up with schtuff.
    90Brougham350's Avatar
    90Brougham350 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
    Jan 2005
    River Falls, WI
    32
    3,730
    Can't really use too much Seafoam, I usually use the whole bottle. I bet Apeman nailed it; your plugs got fouled when you poured it in, probably those years and years of carbon build-up just breaking loose.
    Mar 2006
    27
    111
    Quote Originally Posted by 90Brougham350
    ok its wont idle but it revs ok i cleaned all the plugs but idk i guess ill change them
    Junkman's Avatar
    Junkman is offline Cadillac Owners Fanatic
    Automobile(s): '78 Superior Cadillac Amublance, '69 Miller Meteor Ambulance
    Dec 2004
    Northeast CT
    245
    The best plugs to use in my opinion are Nippendenso, NGK, or Bosch. I have had nothing but trouble from Champions. AC are not much better. Change the plugs and I bet that the problem will go away. Usually does.... Junk...
    Tailfin's Avatar
    Tailfin is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Deville Concours
    Jan 2004
    New York (verified rust state)
    35
    803
    Re: can seafoam mess up my motor
    Unless it's different for the older engines, I'd stay away from Bosch. Those stupid Platinum +2/+4 shroud the spark.
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    Bosch also makes normal sparkplugs - anything other than a single ground strap is a gimmick and a waste of money. The spark can only jump to one.
    If you want better plugs, get platinums and don't worry for the next 100,000 miles.
  10. Remove Advertisements
