electrical problems. HELP!!! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
500, 472, 425, 368 Discussion, electrical problems. HELP!!! in Cadillac Engine Discussion; It's a good idea to check out that fuel filter. If your boss knows the condition of a condenser by ...
  1. #16
    Angela Desmond is offline Cadillac Owners Fanatic
    Apr 2003
    new windsor new york
    59
    193
    Re: electrical problems. HELP!!!
    It's a good idea to check out that fuel filter. If your boss knows the condition of a condenser by looking at it, then he is truely an amazing guy.
  2. #17
    1970caddy is offline Cadillac Owners Member
    Jan 2004
    6
    haha, ya i dunno if he looked at the condensor or not, he said the points were good, but i dunno.. would the fuel filter shut the car off, and start right back up after its ready?
  3. #18
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    It could. It's probably a good idea to replace it anyway. Replace the one on the front of the engine first. You can follow the fuel line from the carb down to it if you can't find it. This one is most likely to cause trouble, as the quadrajets have a bypass built in. It might be a good idea to replace the quadrajet one too while your at it.
  5. #19
    MMNineInchNails's Avatar
    MMNineInchNails is offline Cadillac Owners Enthusiast
    Jul 2003
    San Clemente, CA
    29
    989
    With my '70 I only had one fuel filter. The fuel line came straight out of the fuel pump to the carb, then in the little housing where the fuel line connects to the carb is the filter. I just took mine out and put a clear fuel filter there that you can pick up at autozone/kragen/etc.
  6. #20
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Theres SUPPOSED to be two. I was missing the one in the Quadrajet. (well there was part of it, but it sure didn't filter anything...)
  7. #21
    78425sedvil is offline Cadillac Owners Member
    Feb 2004
    Acworth, Georgia
    33
    4
    my 78 sdv has the a similar problem it hesitates when i hit the gas and i have to feather the pedal to get it to stay running but sometimes it stalls altogether backfiring generator light oil light the whole 9 yards i have tried everything from tune up, k&n air filter, and new exaust to get it to breath a little better but nothing has helped so now i beleive it is the accelerator pump on the carb
  8. #22
    Apr 2003
    59
    193
    I just got over a a bad dead spot from a standing start with my Edelbrock 600. Rebuilt the carb and put a new cup on the accelerator pump and now it works fine. Sounds like your pump is the problem to.
  9. Remove Advertisements
